I am putting disc brake spindles onto the front of my Challenger. Unfortunately, they were disassembled when I bought the car, and some of the hardware is missing.
I have a few questions that I hope the kind folks around here can help with:
1) What size bolt and nut are used to hold the caliper adapter to the spindle? (See the first picture below)
2) What size bolt and nut are used to hold the dust shield to the spindle? (See the first picture below)
3) The rotor/hub assemblies I purchased (Wagner) seem to have the inner and outer bearing races already installed - Is that right? (See the second picture below)
4) Which way should the inner bearing grease seal be installed? The FSM says: "...with lip of seal facing inward." In looking at the seals I purchased (Timken), I cannot determine which side is the 'lip of seal'. In the picture at the bottom of this post, I showed direction 'A' and 'B'. Can someone tell me which way this seal should be installed to the hub/rotor?
I am hoping to get the front wheels on the car this weekend, so I appreciate your information!!!
