Good luck with that, I mean that sincerely. I hate network issues. So, for some FYI for you, QoS Packet Scheduler is a protocol designed to funnel and time the delivery of data by delaying the delivery of the packets. So it basically uses a FIFO (First In First Out) process of holding back packets to ensure they deliver correctly, in a scheduled manner not conflicting with other data deliver or within certain time constraints. Modern networks are built with QoS to, hopefully, make the network run smoother with high volumes of data streaming accross. In all likeliness you could uninstall it from all your computers in your house, reboot them and they should reconnect just fine. In general with small networks there is no real need for QoS because the amount of traffic on a single home network isn't enough to cause any significant slow downs. When speed is in question, it's really not a bad idea to just remove any protocol that isn't needed on your network. The more protocols the more network overhead there is. So if you don't need it, don't use it. On my home networks running XP in the past I ran TCP/IP and Print/File Sharing and that was about it since nothing else was required. Good luck with your settings and I hope everything continues to run well.
