Author Topic: Carb Help Needed - Please!!!  (Read 6045 times)
Offline challydust
Re: Carb Help Needed - Please!!!
« Reply #60 on: May 10, 2010 - 07:57:15 PM »
bullit that article a few pages back,..might just have fixed my two summer long problem....i have  a fairly radical hdry roller cam...and i have 7 inches of vacuum at idle...(900)....i went to a 3.5 power valve cause quic fule technology who built it recommended it...ive had a start up smokin problem...only when its cold at start up and after uve driven it then let it sit....then restart it a few hours..its like it dumpin too much fuel...that article kinda sums that up...im wonderin if that been my problem all a long.....about changin that spring deal so the rods arent dumping so much at idle??? hhhhhmmmmmm
« Reply #61 on: May 10, 2010 - 08:07:07 PM »
sounds like the heat from the intake is boiling the fuel over into the manifold
 do you have a 1215 Felpro intake gasket under the intake to block the port , if it is a 440 , if not install the gasket
« Reply #62 on: May 10, 2010 - 10:03:08 PM »
challydust,  The only carb. article I see is from Edelbrock, I'm sure there's some info that would transfer but if you have a power valve chances are it's a Holley or like carb & will not have springs or rods.
Offline challydust
« Reply #63 on: May 11, 2010 - 01:10:11 PM »
good point guys....chryco yes u mention this to me in a private message thank u....my engine is  a 400 low deck...would there be  a diff then?....bullit...yes....i have  a 850 quick fuel, which is a hooley look like...lol...told ya i didnt know **** about carbs man...;).....so no rods or springs to adjust...:(.....see what chryco says about my 400 and go from there...about the fuel boiling..
« Reply #64 on: May 12, 2010 - 12:03:57 PM »
1214 is the part # for the low deck
Offline challydust
« Reply #65 on: May 12, 2010 - 12:34:45 PM »
Thhank you chryco! :worshippy
Offline challydust
« Reply #66 on: May 12, 2010 - 12:36:44 PM »
hey chryco....does that still hold true about the fuel boiling over,...even if the car is cold?
« Reply #67 on: May 12, 2010 - 06:08:14 PM »
when you shut the car off hot the fuel will boil over & pool in the intake , even if the car sits until cold the fuel in the intake will not significantly evaporate leaving it rich on restart & if you pump the throttle even just once before starting it it will be even harder to start .
Offline challydust
« Reply #68 on: May 13, 2010 - 02:15:50 PM »
okay makes sense , thanks....i never usually pump it, it usually fires up pretty easy...but i see what u r saying...ill check into it ;)
