Yeah, I picked up an FSM, and I've gone through that portion of it. I've also replaced the voltage regulator. I think there must be a voltage drop somewhere between the voltage regulator and battery, but if thats causing a low signal to the regulator, it should be making the alternator overcharge, but it's not charging at all. If I disconnect the bat cable from the alternator, it reads only .4 volts or so. I've take multiple electrical engineering courses only a few years ago, and I still can't figure this one out. Sorry if it's question after question, I'm just at a loss
