Author Topic: Rear Drum Removal - What's the trick?!?!?!?!?!  (Read 1183 times)
Offline CUDA JAS
  • vroooooom!
« on: March 08, 2010 - 12:57:46 PM »
Ok, So I know I have to back of the self-adjuster to get the rear drum off..but I cannot seem to get the thing to move!!
What is the trick to moving the damn little locking arm (or what ever it is called)?  :stomp: :swear: :stomp: :swear: :pullinghair: :pullinghair: :banghead:
HELP please!!!!!
74 'cuda 360/727
Just call me a gearhead!
Re: Rear Drum Removal - What's the trick?!?!?!?!?!
« Reply #1 on: March 08, 2010 - 07:47:12 PM »
I move it off the adjuster 'star' wheel with a small flat blade screwdriver, then use another screwdriver to turn the wheel. :2cents:
Offline CHL2T
  • Handle it, man!
« Reply #2 on: March 08, 2010 - 09:51:08 PM »
 :iagree: Yep, it's a two flathead screwdriver job along with a lot of patience, poke one into one of the holes and feel for either the arm or the star, once you find one, the other is easy,
 good luck :2thumbs:
« Reply #3 on: March 08, 2010 - 09:55:32 PM »
Sometimes the drums get a lip on the outer edge and don't want to let go. I used to do brake jobs alot and ran into this problem. Get creative with a couple of screwdrivers once the star adjuster is backed off completely.
Think of it like getting a paint lid can top off but doing it so that it comes off evenly without one edge more than the opposite side.
Try this.
One side begins to come up at 12 o'clock, Go to about 4 o'clock and do a  little. Then 8 o'clock. then back to 12 o'clock. Repeat in gradual amounts of it coming off.
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: March 10, 2010 - 01:02:52 PM »
Thanks guys.
I can find the star wheel, but I can not seem to find the arm.  Oh well, I will give it another shot this weekend!!
Jason
74 'cuda 360/727
« Reply #5 on: March 10, 2010 - 07:59:13 PM »
It should be just on the back side of the star. With your screwdriver beside the star wheel, just move it in until it contacts the plate. Should hit it within a 1/2" or so. Push a little harder and it should move off the star wheel.
« Reply #6 on: March 11, 2010 - 01:01:27 AM »
you have 2 holes to work through , with a small flashlight you should be able to get enough light in there to see the star wheel , , you need to rotate the star wheel down
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #7 on: March 11, 2010 - 03:10:02 AM »
This is your goal
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Aussie Challenger
« Reply #8 on: March 11, 2010 - 04:42:15 AM »
Good pic Hood, I have also seen where the self adjuster has been removed and the lower spring holding the adjuster into the shoes at the bottom has jammed the adjuster, this spring is missing in Hoods photo.   :2thumbs:
