Author Topic: front and rear glass  (Read 1189 times)
Offline Lovemy440
  • mopar or no car
« on: September 26, 2004 - 04:45:23 PM »
trying to get this Freaking glass out but its got tons of this black tar stuff holden them in.
my ? is how do i remove this stupid glass?
Nos is neat,
Injection hard to beat
But when it"s time to get goin
I'd rather be blown
Offline 360 'CUDA
Re: front and rear glass
« Reply #1 on: September 26, 2004 - 05:12:54 PM »
You mean the quarter glass right?
roll it halfway down and start pulling
If your talking about the back glass then the best way I have found is with a strand of E-brake
cable with a vice grip on each end
Stick the strand through in one spot and clamp the vicegrips on each end and pull back and forth
all around the edges
You can do it that on the windshield too but you have to be carefull if you want to save it without
any cracks
Offline rnsykes
« Reply #2 on: September 27, 2004 - 11:41:59 AM »
The piano wire works well, but make sure you remove the trim clips because they are hard to see once they are burried in the window adhesive.  No sence sawing into one of them.  Also, be very very careful.  Make sure you cut all the way through, and don't just cut three sides and try to lift it out.  The rear glass is critical since it's very hard to find.  Front windshields are still repro'd and readily available.  It took me months to find a rear one, and had to settle on a used one.
« Reply #3 on: September 28, 2004 - 03:07:24 AM »
there is a special cutter , with a L shaped blade to cut the seal around the glass , usually under $10 to buy one
