Author Topic: positioning a rearend . need some help...  (Read 1277 times)
Offline dutch
« on: March 12, 2010 - 01:46:17 PM »
so today I took a good look at my dana rearend, and that left me with some more questions.
when the rear was still in the car I noticed it wasn`t straight under the body.  one side was further to the front of the car than the other. Something else that caught my attention at the time was that there was not even a 1/4" between the tires and the leafsprings, with 15"x7 rallye`s and a 255 tire  ???  there were aluminum wedges between rear & spring, the tabs that hold the rear in position on the springs are not on at the same angle and the welds are great  :woo: :faint:
so, I will have to cut off the crap and start over...  ::)    what would be the best way to tackle this?  how do I make sure the pinion-angle is correct?  ( is that even possible with no driveline in the car? )   Where do I get my measurements from? front end / body / framerails ect...?
another question...
can anyone tell me what the rear came out of ?  just curious...
another thing that caught my eye was the difference in axle seals left & right... is this normal for the dana 60?
« Last Edit: March 12, 2010 - 02:34:00 PM by dutch »
*** Bart ***
Offline Challenger III
Re: positioning a rearend . need some help...
« Reply #1 on: March 12, 2010 - 08:00:18 PM »
1968 - 1969 B Body 4.10 Powr-Lok. Hope this helps.
Mike :wave:
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline Aussie Challenger
« Reply #2 on: March 13, 2010 - 02:02:58 AM »
If one side is further forward than the other then the spring centre bolts are not locating the axle housing, one is either broken or missing. You mentioned that there were wedges, if one was installed it could have raised the spring saddle so the centre bolt wouldn't locate it.
You will need to check that both saddles are welded at the same angle as it looks like a non factory weld in the picture.    :cheers:
Offline dutch
« Reply #3 on: March 13, 2010 - 02:30:00 AM »
the saddles are not welded at the same angle and the holes don`t measure the same distance to the tube either...  in other words,  one hole is further to the front of the car than the other...
I suppose I would be ok if I make new saddles , make sure the holes & other distances are correct and weld them on,  BUT.... how do I position the pinion angle correct..?
*** Bart ***
Offline dutch
« Reply #4 on: March 13, 2010 - 05:30:58 AM »
Mike :wave:
thanks mike, I thought it might be a b-body rear.
might be a good time to move the springsaddles a bit towards the centresection, and relocate the springshackles
*** Bart ***
« Reply #5 on: March 13, 2010 - 01:02:50 PM »
That's a great idea, Dutch. I've found the best way to set up a rear end is to bolt it in with the perches not welded, carefully measure everything, including wheel / tire clearances. Load the springs, if you can, with the weight of the car and aim the pinion slightly lower than the trans tailshaft / yoke. If this stuff is not in the car yet - you can weld it up when it is! Works for me! :woo:
« Last Edit: March 13, 2010 - 01:06:25 PM by Challenger III »
