Author Topic: New fuel tank for 70 Challenger  (Read 1751 times)
Offline 1970ChallySE
« on: March 12, 2010 - 02:32:22 PM »
I was thinking about swapping my old fuel tank for a new one in my '70 Challenger.  Does anybody have any recommendations about where to go and what I need to get, as well as anything else that I might need to for it?  I appreciate anyone's help.
Offline Cuda Cody
  • Vancouver, WA
Re: New fuel tank for 70 Challenger
« Reply #1 on: March 12, 2010 - 02:39:59 PM »
Call Dave at Roseville Moparts.  He's very knowledgeable and will hep you.  They are a site supporter and their prices are great.
« Reply #2 on: March 12, 2010 - 02:54:52 PM »
I appreciate the advice.  I have gotten some other stuff from Dave.  I will give him a call.
« Reply #3 on: March 22, 2010 - 12:22:27 PM »
I have seen where there are two replacement fuel tanks.  One is with ECU and the other is without ECU.  I was told that the difference is that one has 1 vent hose on the right side.  The other has 4 vent hoses on the right side.  I have tried to look at my tank while it is still in my car.  The only thing I can see on that side is the filler neck.  Can anyone offer any help?
Does type of car and engine make any difference?  My car is a '70 SE that originally had a 318.  As far as I know, my car was never a California car, so it most likely did not have the emissions stuff on it.
I appreciate any insight.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: March 22, 2010 - 01:28:49 PM »
if your heat shield are in you may not be able to see. In the right side of the trunk do you have a tube looping up and down or do you have a large pipe coming up from the floor.  if you have just the small tubing it is a one vent, if you have the large pipe looking vent, then its a 4.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #5 on: March 22, 2010 - 06:51:56 PM »
The only thing I can recall off-hand from looking in the trunk is the filler tube (where the fuel flows from the outside down into the tank).  That is probably not what you are referring to, though, or is it?
« Last Edit: March 22, 2010 - 07:19:34 PM by 1970ChallySE »
« Reply #6 on: March 24, 2010 - 11:06:09 AM »
I found it, Dave!  It has 1 vent hose.  Thank you for your help!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #7 on: March 24, 2010 - 03:40:48 PM »
cool beans,  :2thumbs:
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Alaskan_TA
« Reply #8 on: March 25, 2010 - 01:14:33 AM »
1970 challenger trunk with N95;
Alaskan_TA
« Reply #9 on: March 25, 2010 - 01:20:33 AM »
Without N95;
« Reply #10 on: March 25, 2010 - 01:40:06 AM »
I have the N95 and noticed someone just looped the nipples at the tank. Should I just use rubber hose to connect to the tube in the trunk? I just want funcionality , originallity isen't important.  Does it mater what hoses go where?
Thanks Brad
