Author Topic: Mopar 440 M1 Intake 4529118 same as Eddy DP4B ?  (Read 8011 times)
Offline outlawse
« on: March 13, 2010 - 02:45:43 PM »
Guys, is the Mopar dual plane M1 intake (Part # 4529118), looks like a stock intake but in alum, the same as the Eddy DP4B ???
I have heard it is and also that it's just a 1969 intake cast in alum ?
Which one is it ...... ?
Thanks....
1972 Dodge Challenger
1970 446 RB: Six-Pack cam, M1 Dual plane Intake, Hooker Headers, much more...
Turbo Action 727: 3400 Stall, Manual Cheetah Valve Body - 3.91 Gears
On bench:  Performer RPM Intake, 509 114 LSA Cam, 440 Source Heads
Offline outlawse
Re: Mopar 440 M1 Intake 4529118 same as Eddy DP4B ?
« Reply #1 on: March 13, 2010 - 02:46:54 PM »
THE EDDY DP4B intake....
Offline Road_Runner
« Reply #2 on: March 13, 2010 - 04:36:54 PM »
Back in the 70's I ran the 383 version of the DP4B on my 70 Roadrunner, and right now I've got the M1 Dual Plane on it after I took the six pack off primarily because I needed something stock height for the Airgrabber to fit.  I'm pretty sure the Mopar intake is stock height, the DP4B may be a little more of a 'high-rise' than stock.  It was a great manifold back in the day, but I think it was Mopar Performance magazine that did a comparison of both these manifolds along with several others including the newer Edelbrock Performer RPM which skunked them all performance-wise.  Either the DP4B or M1 would be a decent stock replacement though.  :2cents:
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #3 on: March 13, 2010 - 07:39:01 PM »
the Mopar M1 intake is better than the eddy , & the Mopar intake is basically the 68-69 iron intake redone in Alum
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: March 13, 2010 - 10:12:54 PM »
Last year, Hot Rod ran a bunch of intake tests on a warmed up 383.  The M1 did very well...and the Holley Street Dominator did as well.
I think Sledgehammer posted the link recently but I don't see it....so here it is again, fwiw
http://www.hotrod.com/techarticles/hrdp_0801_mopar_intake_manifolds/index.html
Offline outlawse
« Reply #5 on: March 14, 2010 - 08:08:36 PM »
so the intake is nothing but a alum 1969 intake.   That sucks.....
Guess it's coming off for a Performer RPM.
How do you think the six-pack CAM will run with the RPM ?  Think it will pull harder to 5K???
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: March 14, 2010 - 11:58:43 PM »
Just realized there is a single plane M1 that is the subject of the tests.
« Last Edit: March 15, 2010 - 12:17:25 AM by Strawdawg »
Offline outlawse
« Reply #7 on: March 15, 2010 - 09:25:20 AM »
What else do I need to install the Performer RPM intake.
I'll get all the gaskets, new intake bolts, and I already have a drop base filter.
Will my throttle cable be long enough and how about my 727 kickdown ?
DO I need anything else ??
« Reply #8 on: March 15, 2010 - 11:03:54 AM »
make sure you use washers under the intake bolts
if it is a 383 I would use the 1214 Flepro intake gasket or 1215 for a 440
youy may need to make an extension for the throttle cable
Offline outlawse
« Reply #9 on: March 15, 2010 - 03:15:19 PM »
UPDATE:
While going threw my dads garage today, I found a new in box Eddy Torker 440.
So I am thinking,..... how would the Mopar 484 cam (114 LSA) work with the Torker?
Its the orginal design which I have heard is better...
Thanks..
Offline Road_Runner
« Reply #10 on: March 15, 2010 - 05:37:53 PM »
UPDATE:
Thanks..
I also ran (and still have in a box somewhere) a torker on my 383 for a couple of years when I was regularly dragracing my RR on a 1/8th mile track.  The 383 loved this manifold, decent mid-range and good top-end power.  I was running a 4.10 rear and 10 1/2" torque converter, a high lift high overlap Crane Cam & 12:1 TRWs which worked great together.  It was bracket racing and I routinely ran in a class where almost all the other cars were trailered race-only cars.  That I recall this manifold faired fairly well in the manifold comparison linked to above.  The only reason I took mine off is I wanted to be able to use the stock Airgrabber aircleaner and the Torker was too tall.  Great find?  (you need any help looking around your fathers garage?  :bigsmile:)
Later, Jim
« Reply #11 on: March 16, 2010 - 01:49:32 AM »
The torker works well  :2thumbs:
Offline challydust
« Reply #12 on: April 16, 2010 - 01:17:28 PM »
any ideas on the m1 single plain vs the dual for the street 90% of the time..im running the mi single now on my stroker...and very happy...just wonderin if any one else has commments on the dual for the street with a stroker 500 and under cubic inch
« Reply #13 on: April 16, 2010 - 07:00:30 PM »
Unless you are into racing red light to red light, you are fine with what you have.    :2cents:
« Reply #14 on: April 17, 2010 - 04:04:26 AM »
