Author Topic: which overhauling kit will fit?  (Read 1209 times)
Offline willard
    • 1970 Challenger R/T
« on: March 15, 2010 - 06:34:44 AM »
Hi, I have a 1968 727 (for 383-4) and want to rebuild it. I'm making a n order at summit but something is not clear in TCI descriptions.
Munroe's book states 19 spline input shaft was 1962-66 and 24 spline 1967-up.
My tranny has 24 spline input shaft.
However when I look at the kits:
http://www.summitracing.com/parts/TCI-149000/   - 1962-70 19 spline (?)
http://www.summitracing.com/parts/TCI-149300/   - 71-up  24 spl.
thay state 19 spline is 1962-1970 and 24 71 - up. What kit should I buy? AFAIK there is some differences in internal parts before and after 1970.
TCi webpage says the same: http://www.tciauto.com/Products/ServiceKits/default.asp
Or maybe I should buy this kit:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380213615929
« Last Edit: March 15, 2010 - 06:37:14 AM by willard »
1970 383 R/T SE
Offline tactransman
Re: which overhauling kit will fit?
« Reply #1 on: March 15, 2010 - 11:52:23 AM »
Get your parts from here,Summit is too high!!
http://www.transmissionpartsusa.com/TF8_A727_36RH_37RH_Transmission_Parts_s/1328.htm
The Summit year info is incorrect.
Terry-tactransman
Union, Mo.
Offline willard
« Reply #2 on: March 15, 2010 - 12:52:57 PM »
thanks - they have nice prices ;)
tactransman - will this part
http://www.transmissionpartsusa.com/Neutral_safety_switch_detent_insulator_kit_p/400-002222903.htm
convert my 1968 detent lever to work properly with 3 prong NSS? I dont like revere to light on bth reverse and drive...
this is my VB:
1970 383 R/T SE
Offline tactransman
« Reply #3 on: March 15, 2010 - 01:04:27 PM »
this is my VB:
No,you just need a different switch:
http://www.transmissionpartsusa.com/TF6_TF8_Long_3_Prong_Neutral_Switch_1968_77_p/540-00054386b.htm
Terry-tactransman
Union, Mo.
Offline willard
« Reply #4 on: March 15, 2010 - 01:11:34 PM »
I dont know if I got it.
I have the 3 prong switch but the old (68) detent lever activates REVERSE light on both R and D-2-1 shifter positions. I thought that I had to change the lever - so that it gounds the switch in P and N to activate starter relay and push the ball in with plastic part in all but R positions. Am I right?
So how that the switch in the link work with 69 detent lever - I will be only activate in R and N positons - when detent lever "fingers" touch the NSS. They lever wont touch the NSS in any other position now - and that why the reverse is it on R and D-2-1.
« Last Edit: March 15, 2010 - 01:21:06 PM by willard »
1970 383 R/T SE
Offline tactransman
« Reply #5 on: March 15, 2010 - 01:53:47 PM »
I have used the late three prong switch on that style lever and it has worked. When the points touch the center metal piece in the switch,it grounds the relay for the starter. When the switch is in the center "dipped" area,it pops the switch plunger out all the way and activates the rev lights. You should be able to have the rev lights on with the switch unscrewed out of the transmission and the connector plugged onto it and the key in the "on" position.. If they do not come on,then with it all plugged in and the key on,push in and out on the switch plunger and see if they blink on and off.
Terry-tactransman
Union, Mo.
Offline willard
« Reply #6 on: March 15, 2010 - 02:40:30 PM »
All you wrote is true but it works the same in R and D21 position.
In other words - nothing else in the car "tells" the reverse light to turn on than that lever. When in R - the dipped part lets the switch activate connection - and the same occurs when the lever is in D21 (no contact of lever with switch).
The later type lever with plastic sleeve is longer - the plastic sleeve pushes the ball (plunger) of NSS inside when in D21 thus the reverse light is on only in the R position - when the ball (plunger) is out - in D21 the plastic arm pushes it in.
BTW my switch was working OK whan the car was driveable but rev light went on on both R and D21 shifter positions.
« Last Edit: March 15, 2010 - 02:43:40 PM by willard »
1970 383 R/T SE
Offline tactransman
« Reply #7 on: March 16, 2010 - 10:35:24 AM »
You have to change the WHOLE VB then. The "rooster comb" is a different shape for the late style switches.
Terry-tactransman
Union, Mo.
Offline willard
« Reply #8 on: March 16, 2010 - 11:32:11 AM »
hmm. and what you think about this item description:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370324182472&ssPageName=STRK:MEWAX:IT
especially this:
Quote
Interchanges on 1966-1968 valve bodies, and will work correctly with the 1964-1968 single-post neutral safety switch; will NOT interchange on 1971+ valve bodies.
1970 383 R/T SE
Offline tactransman
« Reply #9 on: March 16, 2010 - 11:37:59 AM »
That looks like exactly what you need. (if the pic is correct)
Will NOT work
« Last Edit: March 16, 2010 - 12:03:10 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline willard
« Reply #10 on: March 16, 2010 - 11:44:22 AM »
I hope so - he has another lever for 1971+ VB:
http://cgi.ebay.com/ebaymotors/Torqueflite-727-and-904-Valve-Body-MANUAL-Lever-1971-/370336655237
and it looks different. So I'll order one and after rebuild we'll see if it works.
Thanks for help!
1970 383 R/T SE
Offline tactransman
« Reply #11 on: March 16, 2010 - 12:01:39 PM »
I modified the above post for clarification.  :cheers:
« Last Edit: March 16, 2010 - 12:03:51 PM by tactransman »
Terry-tactransman
Union, Mo.
