Author Topic: Headlight Relays  (Read 15258 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: Headlight Relays
« Reply #15 on: March 16, 2010 - 06:53:18 PM »
I have mine under too, about 15 dollars with the relays and connectors.  My third relay is for the Fog lamps.
Tom
No one notices the stuff under the tray, and it doesn't seem to get wet at all.  I think Brad70 can attest to the rain driving during Carlisle last year!
Tom
« Reply #16 on: March 16, 2010 - 08:21:27 PM »
I added the 3rd relay for the running/parking lights.
Just the front half, or did you run a wire back inside? :popcorn:
Offline VTMopar
« Reply #17 on: March 16, 2010 - 08:40:00 PM »
Chryco - Mike - et al.....  Thanks!  This is very helpful.
Any suggestions on where to pick up the relays?
VTMopar
VT MOPAR
Offline GoodysGotaCuda
« Reply #18 on: March 16, 2010 - 09:27:08 PM »
Used to have a writeup on my setup, but I've since quit hosting the site unfortunately.  Everyone has pretty much covered it pretty well. Going with HIDs relatively soon on mine, heck with halogens!
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #19 on: March 17, 2010 - 04:36:35 AM »
usually I just get them at the wreckers , all the newer vehicles are wired this way & use a std relay , I look in the Mopars usually , they have a fuse block under hood with typically 5-8 relays
Offline willard
    • 1970 Challenger R/T
« Reply #20 on: March 17, 2010 - 05:18:33 AM »
I guess every electrical store should carry these - here we can buy relays in every auto store or shops carrying radio ham equipment (CB radios, auto alarms etc). They cost about $3/ea.
1970 383 R/T SE
Offline Katfish
  • 70 Challenger
« Reply #21 on: March 17, 2010 - 05:55:16 AM »
Offline UKcuda
  • Tell them I'm on my way
« Reply #22 on: March 17, 2010 - 02:13:06 PM »
Quote
LOL - I got mine off a scrap '95 Jeep, but they weren't the ones in the box - I think someone had wired spot lights or something to it as well so it had these two on a separate bracket.
I took the black plastic relay/fuse box as well though and one day I might use it as a replacement for the rat's nest that's under my dash - double LOL
'72 'cuda
« Reply #23 on: March 17, 2010 - 06:19:46 PM »
here they are over $10 each new + pigtail for more $$
Offline UKcuda
« Reply #24 on: March 17, 2010 - 08:01:25 PM »
Quote
That's a bit steep - you can get a bag of 'em from china with brackets and tails for that sort of money.
If enough guys on here want them (and can't be bothered going down the junk yard) they should put in a bulk order.
'72 'cuda
Offline VTMopar
« Reply #25 on: March 17, 2010 - 09:14:36 PM »
I picked up 2 40 amp relays; some 14 gauge wire; a bunch of various wire connectors; and a fuse link today at Advance Auto for about $15.00    I looked under the hood -- followed the existing wiring.... got cold feet and decided to go look at Chryco's write-up a few more times.....
So -- where should I start (remember, this is all new for me  :22yikes:
I liked the idea of hiding them under the batterty tray -- but I think I'll focus on getting them installed & workng first.   Anybody got any pics of the various connecting/splicing locations?
VT Mopar
VT MOPAR
« Reply #26 on: March 17, 2010 - 10:25:27 PM »
if you hide them under the battery tray you will have to lengthen the wires , I cut the two wires behind the headlights on the left side
Offline Aussie Challenger
« Reply #27 on: March 18, 2010 - 06:27:04 AM »
It is a pity that Goodys link is gone but if you follow Chryco's advise, do it slowly it really is easy. Take out the battery so you have more room, but identify which wires are which first.   :2thumbs:
Offline 422STROKER
« Reply #28 on: March 18, 2010 - 06:13:05 PM »
FWIW I made Headlight jumpers so I didn't have to cut any original wiring.  Basically put spade connectors(properly sized) for the original harness to plug into the new setup.  They sell a replacement headlamp harness at the parts store for a couple bucks.  Using the original headlamp feeds as the "trigger" for the relay.  This way you can mess up the original stuff.  Add a line fused off the battery relay terminal for a clean stealthy look under the tray.  It is very easy, just take your time and make good connections.
Tom
Tom
« Reply #29 on: March 18, 2010 - 06:23:23 PM »
Tom, or anyone else that has done this,
  Do you notice a difference in brightness of the headlights? I have the relays and wires, but I haven't gotten to the mounting and hacking into the harness part yet.
