Author Topic: shelf speakers bass response  (Read 2505 times)
Offline UKcuda
  • Tell them I'm on my way
« on: March 16, 2010 - 05:38:13 PM »
Now I'm using the car a lot I'm really glad I bothered to sound-proof it so I can actually hear the stereo, even cruising along at 75 it's pretty good.  The only problem is I am getting very little bass from the rear speakers.
I have some smaller 2 way speakers in the foot wells, but they are not intended to be bassy anyway.
Under the parcel shelf I have a couple of clarion units, about 7 inch, they should be sounding better than this.  I am wondering if the problem is that there is nothing behind them.  I mean they are open to the trunk area behind.
I was wondering if fitting some kind of enclosure behind them might help?  Like so they have a cabinet ?
Any ideas?
The system is MP3 through a 40 Watt Kenwood radio/tape deck.  It's plenty loud enough, even though the only thing I paid for was the speaker wires :icon16:
« Last Edit: March 16, 2010 - 05:41:34 PM by UKcuda »
'72 'cuda
Re: shelf speakers bass response
« Reply #1 on: March 16, 2010 - 06:00:42 PM »
   6x9s in the parcel shelf are the norm...building properly sized enclosure should stiffen the base.
 I added a 10" sub & amp that made a big difference..  Planning on mounting it to a board just behind the back seat & building a shallow wide enclosure to save trunk space.
Offline UKcuda
« Reply #2 on: March 16, 2010 - 06:23:58 PM »
Yeah, I thought about using a sub but I'm pushing the family's muscle car budget a bit at the moment as it is  :clapping:
But these Clarions are reasonably good kit - they should thump it out a bit.
When I sound-proofed I left the trunk untouched and concentrated on isolating the passenger cabin.  I even foam filled the sail panels to close it off.  It worked well.
So, I already closed off the rear seat from the trunk with fibre board and sound deadener, which would make a good mount for a trunk based sub if I made a cut-out into it.
Just think maybe I don't need to if I can get my Clarions to bump better.
It's not a big deal - the sun has been shining the last few days and I've got a 'cuda on the road.  The stereo is a comparatively small concern.
'72 'cuda
« Reply #3 on: March 16, 2010 - 06:32:07 PM »
I have some top of the line 6X9's in the back of mine. I also added an aftermarket amp back there, which is what I think you will need to do.
Offline UKcuda
« Reply #4 on: March 16, 2010 - 07:01:44 PM »
Quote
That's what I was afraid of.
How am I ever going to get my Mustang done with everyone telling me I need to do more on the 'cuda  :roflsmiley:
'72 'cuda
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: March 16, 2010 - 07:21:25 PM »
I'd try the 6x9's in an enclosure of some sort first, should thump ok.  I got this in the trunk, made with left over plywood and some walmart carpet.  Couple of 10's on top.
Tom
Tom
Offline dwbiggs
« Reply #6 on: May 04, 2010 - 10:19:01 AM »
Tom,
How did you secure the enclosure to the car?
Offline UKcuda
« Reply #7 on: May 04, 2010 - 04:36:59 PM »
If it helps, I eventually put my hand in my pocket and bought some 6x9 JBL GTO series 100W/ch speakers and I am very pleased with them.
As far as I am concerned they are plenty bassy enough without an enclosure behind.  I was reading up on it and apparently the key thing about an enclosure is that it  separates the front wave from the back wave.  Seing as I sound-proofed my cabin from the trunk I figured I had already got that.
These fellas go louder than I can stand without distorting and they were not expensive so for me that's a result.
'72 'cuda
Offline 422STROKER
« Reply #8 on: May 04, 2010 - 11:25:58 PM »
Tom,
Friction, I fit the plywood box tight and then added carpet.  It hasn't moved at all, I've been to the track and done some pretty bad donuts and it hasn't moved.
I guess you cold add a bracket from the spare tire lug in the middle there to mechanically secure it.  AMybe I should .LOL
Tom
Tom
