Author Topic: Comp Cams XE274H in a 440  (Read 3544 times)
Offline outlawse
« on: March 16, 2010 - 09:11:15 PM »
Guys:
Does the Comp Cams XE274H produce enough vacum in a 440 for power brakes.
(Comp XE274H   274 / 286   230 / 236   .488 / .491    110   106   60   1800-6000)
The Comp tech I spoke to said that with its 60 deg overlap it should be ok, but....
Anyone have actual experience ????????  Power brakes and Comp XE274H ?
1972 Dodge Challenger
1970 446 RB: Six-Pack cam, M1 Dual plane Intake, Hooker Headers, much more...
Turbo Action 727: 3400 Stall, Manual Cheetah Valve Body - 3.91 Gears
On bench:  Performer RPM Intake, 509 114 LSA Cam, 440 Source Heads
Offline outlawse
Re: Comp Cams XE274H in a 440
« Reply #1 on: March 16, 2010 - 09:13:14 PM »
The tech also told me I could get a custom grind made.
Maybe the Comp XE274H with a 114 LSA ?????  Might be a good idea.
OR should I just stick with the Mopar 484 114 LSA cam ?
« Last Edit: March 16, 2010 - 09:14:48 PM by outlawse »
« Reply #2 on: March 16, 2010 - 09:15:26 PM »
yer avatar pixel  is to big. Please fix it. you show over 3000 x 2000
to answer your question.  I ran that 2 years ago in a 8.1/1 440   the brakes worked good :2thumbs:
Offline moper
« Reply #3 on: March 17, 2010 - 02:43:22 PM »
It's not that big, but I'm not sure if it will run brakes. I think it will depend on the pistons you have and the true compression ratio.
Offline 4 speed fish
« Reply #4 on: March 17, 2010 - 03:02:20 PM »
I am running comps 477-488 cam 110 lope.I have good vacuum for my power brakes.I think you will be fine.
Offline outlawse
« Reply #5 on: March 18, 2010 - 09:26:55 AM »
4-Speed:
Do you like the power range of the XE274 ???  What's your review ?
« Reply #6 on: March 18, 2010 - 11:09:00 AM »
The cars runs strong.The idle is just what I wanted.
