Author Topic: 650 AVS stumbling in hard turns - ideas?  (Read 2757 times)
Offline shadango
Re: 650 AVS stumbling in hard turns - ideas?
« Reply #15 on: March 22, 2010 - 08:12:09 AM »
Add me to the club...eddy carb, hard right up hill will cause it to stumble out......also thought wiring...
Hey its an old car...it is bound to have some quirks.   :bigsmile:  Its really un-nerving though to go into a hard right and think the engine is gonna die out.
What I want to figure out would be the hot start issue...
I have been considering going to another carb brand altogether but just dreaming i guess.
Offline GoodysGotaCuda
« Reply #16 on: March 22, 2010 - 09:23:55 AM »
Whats the hard hot start issue? I can't get mine to foul up when hot. As soon as I can hit the key it's runnin'.
Stumbling may be a little better. I went with a 15/32" bit for the floats, driving it again today to work for a little test n tune
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #17 on: March 22, 2010 - 05:26:19 PM »
Hot hard to start can sometimes be related to hot fuel...do you have a spacer between the carb & intake?.... If not add one...you should get a little better low end response anyway.
Also look at fuel lines in relation to heat sources such as headers, exhaust pipes there are thermal wraps to help that.
  Here's a decent deal on a 1" spacer, just make sure you have room 1st...a 1/2" & 2" also available.
http://cgi.ebay.com/ebaymotors/Phenolic-1-4-Hole-4bbl-Holley-Carb-Spacer-Studs_W0QQcmdZViewItemQQhashZitem4cee5c1334QQitemZ330416526132QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
