Author Topic: Seam sealer?  (Read 1839 times)
Offline 67vertman
  • Member since 9-23-2005
Seam sealer?
« on: March 17, 2010 - 11:42:31 PM »
Has anyone had luck replicating the look of factor seam sealer in thier trunk?
It looks like they used a tool that dispensed the sealer about two inches wide.
any tips or tricks would be great.
Re: Seam sealer?
« Reply #1 on: March 18, 2010 - 12:22:10 AM »
A broken off paint stirring stick will make the grooves.
Looking at it, they might of used at the factory was some type of a pneumatic gun that dispersed it out of a 2 inch hole. It's a big blob of the stuff for seams and they had to work fast of course.
All purpose 3M seam sealer is water diluable when it gets wet. Takes a long time to dry when thick is the downside. Seems workable to duplicate.
Do it in layers. Spray bottle mist it first. So working it to look real might be an option.
Offline elitecustombody
  • Supra collector
Re: Seam sealer?
« Reply #2 on: March 18, 2010 - 12:52:07 AM »
use stiff paint brush dipped in wax & grease remover solvent
Stefan B
Offline 67vertman
Re: Seam sealer?
« Reply #3 on: March 18, 2010 - 08:25:34 PM »
Great tips.  I am not to concerned with 100% factory.  However I don't want it to look like a three year old did it.
Re: Seam sealer?
« Reply #4 on: March 18, 2010 - 09:59:25 PM »
I wanted to ask you Stephan about this earlier.
What brand or type do you typically use?
I tried 3M Fast and Firm but it was too sticky and gooey to get the flowed look. then I hear it cracks later on.
When I used the 3M all purpose seam sealer, I saw how much manageable it was to coax into the right look and it is kinda rubbery.  As I said, it takes too long to dry when it's thick seams.
  • Supra collector
Re: Seam sealer?
« Reply #5 on: March 18, 2010 - 10:58:02 PM »
Mike, stay away from fast n firm,it will crack. I use 8300, don't expect it to stay wet for longer than few minutes, I do a section at a time and move on
Stefan B
Re: Seam sealer?
« Reply #6 on: March 18, 2010 - 11:21:35 PM »
Cool, I just bought some a few days ago.  :thumbsup:
Offline 67vertman
Re: Seam sealer?
« Reply #7 on: March 19, 2010 - 12:16:20 AM »
I bought two tubes of white, for around the wheel wells and rear panel.  I also bought one tube of black for the front edge of the trunk pan, close to the back seat, as that is how my car came from the factory.
As you can see, even the factory sealer looks uneven.
Offline ksierens
    • 70 Challenger Resurrection
Re: Seam sealer?
« Reply #8 on: March 19, 2010 - 08:25:23 AM »
I used a brushable sealer that comes in a can and cut the bristles back on 2" brush.
Kurt - SE Michigan
Re: Seam sealer?
« Reply #9 on: March 19, 2010 - 10:38:06 AM »
Quote
IF you had a three year old do it, it would probablly come out looking 100% correct. :lol:
Offline ksierens
Re: Seam sealer?
« Reply #10 on: March 19, 2010 - 11:29:06 AM »
I tried to be a little sloppy when I did mine, trying to think like a line worker!
Kurt - SE Michigan
Offline 67vertman
Re: Seam sealer?
« Reply #11 on: March 20, 2010 - 05:34:24 PM »
After relooking at the photos, when I posted them, it does look like a three year old work as a line worker.   :crazy:
