This bog is the response of the engine to the sudden loading of the engine, after being allowed to spin freely. If you close the throttle when this happens, it will be worse (even leading to a stall). When the air and fuel demands change suddenly like this, the usual response is a stumble, or bog. This is nrmal, but frustrating. You might also have the carb a little rich, which will exacerbate the issue.
