Author Topic: i need help trying to mount my clutch fork  (Read 1099 times)
Offline 505challenger
« on: March 18, 2010 - 02:58:41 PM »
i am converting my challenger to a 4-speed and cant figure out how to mount the clutch fork and pivot.  if anyone has any pics of how it mounts i would greatly appreciate it.
Offline 73EStroker
Re: i need help trying to mount my clutch fork
« Reply #1 on: March 25, 2010 - 07:36:16 PM »
The pivot bracket mounts to the left of the front bearing retainer on to the bellhousing. There should be 2 x 5/16" bolt holes there to accept this bracket. Be careful as there are a few variations of the bracket you need which depends on the body style and whether you are using a BB or SB. Also the BB clutch fork is about 10-3/4" long and that makes it shorter than the SB version which is about 12". Brewers has all the stuff you need.
Barry (Salmon Arm)
« Reply #2 on: March 27, 2010 - 10:16:52 AM »
thanks for the reply, i see 2 sets of holes on the inside of the bellhousing near the clutch fork opening,  one set is higher than the opening and the other is lower.  neigher of them is centered (where i would assume it would need to be :clueless:
« Reply #3 on: March 27, 2010 - 12:24:25 PM »
ifound a pic of the inside of my bellhousing, maybe someone could tell me wich 2 holes i need to be using
http://www.aaaaautomotive.com/Shop/Control/Product/fp/SFV/32785/vpid/6720783/vpcsid/0/rid/134382
Offline Changin Gears
« Reply #4 on: March 27, 2010 - 12:48:33 PM »
Here is a picture with the bracket mounted
« Reply #5 on: March 28, 2010 - 11:18:13 AM »
thats exacly what i was looking for, thanks.  my bellhousing doesnt have those holes thats why i was so confused.  brewers has the right one that i need.  thanks again for the pic, its worth a thousand words :cheers:
