Sounds like timing at idle, with no advance. How did you check your timing? 36 degrees total would be with vacuum disconnected, and engine running above max rpm for advance weights to overcome springs. With only 16 degrees, you would be severely retarded at idle (something like 20 degrees ATDC), and the engine wouldn't even start. Setting your initial timing at 16 degrees BTDC is a good starting pint, although you might be better off at 14. As Oldschool said, you have to experiment.
