Ammeter wire burning?
My car started sputtering and then shut off today, and I pulled off the road. At first I saw smoke coming out the front of the shaker, but now I think that was just unburned gas vapors.
I let it cool (and myself!) a few minutes, and tried starting again. Nothing. This happened before so I checked the ballast wires, and sure enough they were both very loose, but I couldnt get either one to click on. They just sort of hang on there barely. Anyway after jiggling with them it started turning over, but no firing. Maybe the ballast is fried, but...then I noticed smoke coming out my driver side defrost vent as I was cranking. I'm not sure but it must be coming from behind the instruments.
I did an alternator to starter relay bypass months ago, using about a 10 or 12 gauge wire, but I didnt disconnect the ammeter. It still reads something, but I know its not accurate.
Where should I start looking before pulling the whole dash apart?
Thanks.
