Author Topic: help no spark  (Read 4328 times)
Offline rebelcuda73
help no spark
« on: March 20, 2010 - 07:27:33 PM »
Car was running and was shut down.Tried to restart it cranks fine but will not turn over.Checked for spark at coil and got none.New coil,voltage regulator and starter relay.
Offline GoodysGotaCuda
Re: help no spark
« Reply #1 on: March 20, 2010 - 07:32:02 PM »
Voltage regulator and starter relay aren't quite related to the ignition circuit. Regular is kinda tied in there, but shouldn't affect your spark. Check power to the coil when cranking? Could be a faulty ballast resistor. Points or electronic ignition?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline rebelcuda73
Re: help no spark
« Reply #2 on: March 20, 2010 - 08:52:12 PM »
With the key in the start postion it shows 5.5 volts.I didn't check it while it starts,what should the voltage be?Also how do you tell if the ballast is no good I did remove it and then renstall it.It's been one thing after another with this car.Thanks Chris
Offline CHL2T
  • Handle it, man!
Re: help no spark
« Reply #3 on: March 20, 2010 - 10:48:58 PM »
Well, it is a 37 year old car.
 Check the ecu, or better yet get a new one. My Challenger did the same thing, it started with the resistor, then the coil, then the ecu then the bulkhed disconnect then the ammeter and so on and so on
Keep at it and you shall have success :2thumbs:
Re: help no spark
« Reply #4 on: March 21, 2010 - 01:19:58 AM »
5.5 sounds about right with the key on, when 'cranking' it should be 11v+ at the coil. Be sure to check it while cranking.
1976 Dodge Warlock
Offline Super Blue 72
    • Phil's Super Blue '72
Re: help no spark
« Reply #5 on: March 21, 2010 - 02:59:18 PM »
Make sure the ECU has a good ground at the mounting bolts.   A new one can found at a local parts store for like $20 or so.
Check out this article, good read for a dead car:
http://www.moparaction.com/Tech/archive/roadside.html
Re: help no spark
« Reply #6 on: March 21, 2010 - 04:59:44 PM »
Are you running a stock Mopar ignition system?
Offline rebelcuda73
Re: help no spark
« Reply #7 on: March 22, 2010 - 05:38:25 PM »
Thanks for the advice guys.I am starting to find out thtat everytime I fix one thing something else takes a ****!!! I have a stock set up in this car.I went looking for spare parts in the garage the other day.So far I've come up with a ballast,a ground wire for the firewall ,and if I don't find the ecu I will go out and buy one.I am going to first install the ballast since I had touched that and a couple of other things and the car would'nt start.And install the ground wire and try to start it if that does'nt work I will replace the ecu like you guys suggested hopefully this will work. thanks I will let you know how it works out!!
Offline rebelcuda73
Re: help no spark
« Reply #8 on: March 31, 2010 - 09:05:19 PM »
Well it turns out you guys were right the ecu was no good ,replaced it and it turned right over.It even idled though it still is not right.Having problems with the charging part.Going to start another post regarding that thanks for the help!!! In case anyone needs a ecu I found it 10.00 cheaper at pep boys for 15.99 a borg and warner new!!!
Re: help no spark
« Reply #9 on: April 02, 2010 - 08:18:36 AM »
Good job!  :thumbsup:
And $15.99 is a good deal!  :grinyes:
