Gas Tank removal/repair
Author Topic: Gas Tank removal/repair  (Read 4112 times)
Offline the Wizard
  • Business Manager
  • Imagination is more important than Knowledge - Albert Einstein
Re: Gas Tank removal/repair
« Reply #15 on: March 23, 2010 - 02:03:17 AM »
Eastwood sells a patch kit.  Can anyone tell me how the pad is attached?  Is it glued, or just clamped in place?
Offline Eastwood Company
  • Sponsor
    • Eastwood Company
« Reply #16 on: March 23, 2010 - 09:38:23 AM »
Depending on how small your leak is, we have had good results with out tank sealer kit filling, sealing and repairing pinholes in old tanks. Might be easy option until you get around to tackling replacing the tank? Helps we offer the cuda-challenger member 15% discount too
http://www.eastwood.com/ew-gas-tank-sealer-kits-for-cars.html?srccode=cuda
Also I've had success using this epoxy to fill/cover leaks in tanks. Smooth it on with a putty knife evenly and let cure.
http://www.eastwood.com/pc-7-epoxy-1-2-lb-can.html?srccode=cuda
Please add our Facebook for the most current happenings here at Eastwood!
http://www.facebook.com/eastwoodcompany
Follow our blog for interesting restoration stories and DIY articles!
http://blog.eastwood.com/
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #17 on: March 24, 2010 - 05:22:05 AM »
My tank also developed several pin hole leaks many years ago.  I replaced mine with a tank that came from a '70 Cuda for $15 from the junk yard.  I did not remove the rear valance and had no problems installing it.   I reused my original pick-up and sending unit.  Just my 2¢
« Last Edit: March 24, 2010 - 05:23:48 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
