I have a few items I would like to get out of my barn and other places.
1 ea 741 diff with 3.55 gears open diff.
1 set of torsion bars in great shape out of a 318 std susp. I believe .88 is the size
1 each 69 383 HP block with the steel crank still in it, block looks good and has a cast date of 6-69
1 each 383 short block with I believe 11.5 to one pistons in it, has one piston that has a hole burned through right in the center of it, must have been ran with nitrous or wrong fuel mixture, has the crank and pistons in it still.
72 Dart, take it all or parts, has a 225 slant 6 that has some sort of head problem, could be the head gasket, it will run but gets water in the oil and has a bad miss. The car it is in is a 72 Dart Swinger, no fender tag or no title, it is missing the windshield, the dash, the door handles and window cranks. Has the drive train in it. Good tires and wheels and hub caps.
1 each Dodge truck transmission HD with a PTO on it. Came off of a 74 440 HP, has the bell housing and clutch yoke, the tailhousing yoke is missing the shifter is still on it.
1 ea 8 3/4 e-body banjo housing, has a slight bow if you look down from axle flange to axle flange, believe if I had a good press I could correct it very easily but don't have one.
1 ea 489 diff housing. Diff housing only, missing one bearing adjuster.
1 set of 4, 14" ralley wheels without the rings or center caps in good shape, have brand new tires on them, they would fit a stock 318 Challenger or Cuda.
1 radio out of a late 70's model Mopar, has the auto seek and am/fm it works! Anyone interested in this I will post a picture so you can see if it is what you need. It may be out of a 76 C body but not sure.
There's probably more but I will have to take a walk through my barn and see what is left. Make an offer on any of the stuff and if you can pick it up fine, if not I will ship.
Thanks!!
