Author Topic: Good reusable valve cover gaskets?  (Read 1312 times)
Offline shadango
« on: March 23, 2010 - 08:39:33 AM »
Have found that the reusable valve cover gaslets on my 318 (mopar aluminum valve covers) arent sealing that good...
Can anyone recommend a good set of reusables? Ones that will seal really well?
Offline 4Cruizn
  • HEMI FISH
Re: Good reusable valve cover gaskets?
« Reply #1 on: March 23, 2010 - 08:48:02 AM »
Not sure there is a good re-useable gasket.  Once used they are compressed and don't seal as well the second time around.   :dunno:
Offline shadango
« Reply #2 on: March 23, 2010 - 09:06:13 AM »
I guess I dont HAVE to use a reusable...I mean, aint nothing in there I will need access to over and over and over...
Just figured it would be nice to have that option.... :bigsmile:
Anyone know if the Mopar Arruminum covers use standard cover gaskets or if they are special?
« Last Edit: March 23, 2010 - 11:35:08 AM by shadango »
Offline tommyg29
« Reply #3 on: March 23, 2010 - 01:29:08 PM »
I could be wrong but I think they should be replaced every time. For guys that remove the covers often it must get expensive.
I have the blue moroso gaskets and you can probably reuse them, but takes a lot of work to clean all the old stuff off them before reinstalling.
Paper type gaskets....forget it.
« Reply #4 on: March 23, 2010 - 06:17:42 PM »
On my 440 they are the standard gaskets, I'm sure it's the same for you.  For what it's worth, the gaskets don't cost an arm and a leg, so I buy new each time. I also clean the area around heads good and put a small coat of RTV on each side of the gasket for a little insurance against an oil leak. Maybe I'm paranoid, but I don't have oil leaking from my valve covers either.   :lol:
Offline wally426ci
    • maryland mopars
« Reply #5 on: March 23, 2010 - 06:23:12 PM »
I always get metal core ones. They don't lose there shape by tightening. My truck has rubber coated ones, and the Challenger has cork.  :thumbsup:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline shadango
« Reply #6 on: March 23, 2010 - 06:50:30 PM »
Its not so much the expense as it is the convenience....you can pull the covers as needed and not have to scrape/clean and go out and buy new gaskets.
But like i said, seeing as I dont need to get in there anyways it more or less moot.
 I may just use some permatex on the ones I have already (reusable) deal with it later.
Offline 71chmark
« Reply #7 on: March 23, 2010 - 08:29:09 PM »
I use the blue rubber coated metal core ones I got from Mancicni Racing.  Kinda expensive but I've had my valve covers on and off several times with no lead
ks.
http://chucker54.stores.yahoo.net/mopestcovaco.html
I may be schizophrenic,
Offline erat340
« Reply #8 on: March 23, 2010 - 08:52:33 PM »
Yes... rubber,metal core. Cant remember how many times I had em off & on...no leaks. Your local Mopar dealer should have them.
Offline tommyg29
« Reply #9 on: March 23, 2010 - 08:58:09 PM »
I think the aluminum covers use the same gaskets (but the bolts are longer cause the flange is thicker)
Offline vinb
« Reply #10 on: March 23, 2010 - 09:19:35 PM »
They are a little pricy, I don't know why these went from $19.88 to $57.95 in one year, but they do work...
Mancini Racing or your Mopar dealer.....part # MOPP5249581AB
Offline erat340
« Reply #11 on: March 23, 2010 - 09:33:52 PM »
vinb.   Capitalistic greed at its finest! Taxes hell, lets protest.
Offline shadango
« Reply #12 on: March 24, 2010 - 07:06:30 AM »
Maybe they were mis-priced initially?   :dunno:
Offline vinb
« Reply #13 on: March 24, 2010 - 09:26:51 PM »
Summit , Jeg's & everyone else has them for $50 plus dollars...
I should have bought a bunch at Carlisle last year for $20.00, but if you snooze you lose......
Oh well...
Offline Strawdawg
    • Vortex Buicks
« Reply #14 on: March 24, 2010 - 10:31:09 PM »
there are some steel cored rubber gaskets on ebay between $20-30
