Author Topic: starter fit problem  (Read 671 times)
Offline mojavered
  • Someday!
starter fit problem
« on: March 23, 2010 - 11:52:03 AM »
I bought a starter the other day, a mini, for my 440.  It is for the following apps.
Part Number:   PME 17181
Attributes   Manufacturer : Nippondenso
Starter Type : Offset Gear Reduction
Application Information:   1995 Dodge Truck Ram 1500 1/2 Ton - Pickup
Engines : 5.2 L 318 CID V8
Engines : 3.9 L 239 CID V6
Engines : 5.9 L 360 CID V8
When I tried to install it, it is hitting on the innermost area next to the block.  When it is nbolted in, it will not go all the way flush to the the housing.  My standard started worked fine.  Do I need to grind down part of the starter?  Or should I get a different starter?  If a different one, for what year?  Thanks.
« Last Edit: March 23, 2010 - 12:03:02 PM by mojavered »
Jason
Re: starter fit problem
« Reply #1 on: March 23, 2010 - 12:27:53 PM »
The mini should fit.  The only thing I had to do was remove the extra wiring extension block(I don't know what it's called) that came on the starter.  That part was hitting the block.
« Reply #2 on: March 23, 2010 - 01:32:54 PM »
 :iagree:   same here
« Reply #3 on: March 23, 2010 - 06:19:49 PM »
Same here #3, but this was for a big block...Maybe it applies to small blocks too?   :dunno:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: March 26, 2010 - 09:13:53 PM »
all of those nip starters come with the terminal extension because they are designed for the newer vehicle application.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
