Author Topic: Crank pulley and fan pulley  (Read 1032 times)
Offline mojavered
  • Someday!
« on: March 23, 2010 - 12:30:28 PM »
How much space should there be between the fan and crank pulley on a 440?  It seems that mine are just too close.  Thanks.
Jason
Re: Crank pulley and fan pulley
« Reply #1 on: March 23, 2010 - 10:45:53 PM »
Non ac  they are very close. May not pull the water pump pulley straight off without them touching
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: March 26, 2010 - 09:06:49 PM »
a little more than a C-hair, 3/32 maybe.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline mojavered
  • Someday!
« Reply #3 on: March 26, 2010 - 09:32:03 PM »
What about on an AC car?  It IS an AC car, but now that I think about it, I am not sure if this engine was from an AC car or not.
Jason
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: March 26, 2010 - 10:08:58 PM »
engine doesnt matter it is the pulleys and additional brackets, pulley spacing is still about the same, with the 2 groove wp and 4 groove crank.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mojavered
  • Someday!
« Reply #5 on: March 26, 2010 - 10:56:18 PM »
Yeah, that is kind of what I meant.  I am not so clear sometimes.  I am just not sure if this engine has ever been used in my car and if it were, was it used with AC?  I am not sure.  I have a 4 groove crank pulley and the fan pulley does not line up and it seems to touch.  I am not sure if there is too much paint on it or what.  Also, I am not sure if the water pump, or the area that the fan pulley bolts to on the water pump, can be pulled a little further out?  maMaybe a 1/4" to line up.  Will not do any good though if the pulleys are touching.
« Last Edit: March 26, 2010 - 10:59:23 PM by mojavered »
Jason
Offline mojavered
  • Someday!
« Reply #6 on: April 10, 2010 - 11:44:26 AM »
After getting my crank pulley on, I was trying to line up the fan pulley and still not having any luck.  The two are just too close and end up touching.  Off a 383 I pulled the fan pulley.  This pulley is smaller in diameter and is more shallow compared to mine.  I put the shallow one on and it lines up with the first groove on the crank pulley.  Is this going to be a problem?  I have not tried to put my power steering pump on yet, but doesn't that pulley need the first groove?  Thanks!
Jason
