OK, mechanic had my car for a bit to work on some stuff. I put a proform 950 on the car, it already has headers, intake, hei, but probly stock besides that. I know that carb is too big for a relatively stock motor, but I am going to stroke the motor next spring and only wanted to buy 1 carb....So i got it back, and it ran great on the way home, much better than with the 750 eddy, but close to home it would backfire through the exhaust when i nailed it...fine at part throttle...I checked the timing and the mechanic has it set at 8 degrees..would that cause the backfire, or is it due to the carb being too big? motor is a 72 440 btw
