Author Topic: Street 440 Custom Cam Idea  (Read 839 times)
Offline outlawse
« on: March 24, 2010 - 06:44:54 AM »
Guys:
I plan on getting a custom grind cam for my 440 after talking with a Comp Cam tech concerning my street 440 with power brakes.  He told me as long as the overlap stays around 54 - 57, the brakes should be very nice.  He also taught me how to calculate overlap and such.  I made a excel sheet with a calculator for cam specs and came up with the following:
Cam A = 280 / 288   0.509   114      56   2000-6000    My Specs
Cam B = 274 / 286   0.509   112      56   2000-6000   XE274H (112 LSA & .509 Lift
Which cam would be the better street performer ?  Alittle less duration but tighter LSA (112 vs 114)  OR more cam duration and wider LSA ??
Both cams have the same amount of overlap (56).
Both cams have a .509 lift.  (Tech told me the stock 906 heads magic number is around .510 for flow)
Thanks... John
« Last Edit: March 24, 2010 - 06:47:31 AM by outlawse »
1972 Dodge Challenger
1970 446 RB: Six-Pack cam, M1 Dual plane Intake, Hooker Headers, much more...
Turbo Action 727: 3400 Stall, Manual Cheetah Valve Body - 3.91 Gears
On bench:  Performer RPM Intake, 509 114 LSA Cam, 440 Source Heads
Re: Street 440 Custom Cam Idea
« Reply #1 on: March 24, 2010 - 06:48:07 AM »
I would use the 114* cam with manifolds & the other with headers
Offline outlawse
« Reply #2 on: March 24, 2010 - 06:55:12 AM »
The car has Hooker Super Comp headers. NO manifolds.
Offline moper
« Reply #3 on: March 24, 2010 - 12:24:47 PM »
What is the first cam's duration at .050?
Offline outlawse
« Reply #4 on: March 24, 2010 - 12:43:19 PM »
I am not sure...
The XE274 is 230 / 236
Offline moper
« Reply #5 on: March 24, 2010 - 06:54:17 PM »
I can't find the lobes he suggested in the lobe catalog.. So I'd have to say XE274 as it's a known quantity. But I am not sure it will run your power brakes. Maybe post the rest of the build info, and be detailed.
Offline AMXguy
« Reply #6 on: March 24, 2010 - 09:51:45 PM »
I liked the Ultradyne 288/296  .485 in .507 ex so much i'm putting the same cam in my Super Bee. not a ton of vacuum but even with the six pack plenty for power brakes.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline outlawse
« Reply #7 on: March 26, 2010 - 06:24:58 AM »
AMX:
What was the LSA of that cam ???
The cam should run my power brakes.  The XE268 has a overlap of 54, the XE274 on the 112 LSA drops the overlap to 56 which should be fine.
« Last Edit: March 26, 2010 - 06:31:03 AM by outlawse »
« Reply #8 on: March 26, 2010 - 08:41:42 AM »
They are so close in spec I don't know that you'll "feel" a big difference in performance. Choice would depend on compression ratio and how close you are to detonation. The longer duration will tolerate a hair more squeeze in the chamber.
