Author Topic: steering shaft  (Read 574 times)
Offline dixiedog
steering shaft
« on: March 24, 2010 - 10:45:53 PM »
I have run into a problem and probably made it worse :banghead:.  Iwas rebuilding the coupler on my steering shaft (70 challenger).  Got everything off and went to remove the pin through the center of the shaft, in doing so i braded the pin.  I thought it just knocked out it moved a bit and stopped.  got really frustrated and cut the pin on one side, looked like it may have been bent a little.  I hope in my frustration I haven't messed this up.  Is there something I am missing?  Does it press on and off or what? Please help!!!  Thanks Danny  (I hated to admit what I did on line)
Re: steering shaft
« Reply #1 on: March 24, 2010 - 11:09:55 PM »
Mine came out with few taps of a hammer using an old drill bit as a drift... Soaked it good with penetrating fluid first......I had an issue with the roll pins in the struts....after cutting them I had to drill out, roll pins are hardened, made for some colorful language.
Re: steering shaft
« Reply #2 on: March 25, 2010 - 12:23:41 AM »
solid surface, big hammer, and a flat punch....bam....wellah :ylsuper:   Or press it out. But it does come out.
Offline the_engineers
Re: steering shaft
« Reply #3 on: March 25, 2010 - 09:30:09 AM »
I did the same thing you did.  I had to have mine pressed out.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline dixiedog
Re: steering shaft
« Reply #4 on: March 25, 2010 - 10:04:52 AM »
I was very worried and upset at myself.  I feel better now.  Thanks Guys now I can get back to it.
