Author Topic: Whats the best way to remove and replace an engine?  (Read 6359 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
Re: Whats the best way to remove and replace an engine?
« Reply #15 on: March 26, 2010 - 03:09:41 AM »
Very cool thread!  I had a line on an engine but that fell through, so I don't know what I am going to do.  I do need to rebuild the front end.  Torsion bars, bushings and shocks. And I need to clean up 40 yeas of gunk.  I may build an engine with the help of a friend. In that case I might look into a long term project and do the front end at the same time and lift the car up.
If I were to come across an engine ready to drop in I think I would go from the top since I am familiar with that way.
Offline Aussie Challenger
« Reply #16 on: March 26, 2010 - 04:40:30 AM »
I have done it from up top for over 40 years now but what tipped me towards doing it from underneath this time is that I will be doing some suspension mods so I will do all at once.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #17 on: March 26, 2010 - 08:45:52 AM »
top or bottom, its your preference, opinions either way, But if you paint mark the cam bolts and measure the ride height before you pull, then it is very easy at anytime to pull the motor from the bottom 12 bolts and slide the t-bar back, no need to undo any of the strut rods or ball joints, I would rather do that then pull the front end off or not and risk alot of damage, this can be done with just a simple cherry picker, and some type of cart system for the engine and trans to sit on.  :2cents:
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #18 on: March 26, 2010 - 07:30:31 PM »
You know Dave, I must of had a brain fart for a moment :roflsmiley:  The struts are hooked to the front of the kmember and lower control arm.
Offline ntstlgl1970
  • T a c o c a t
« Reply #19 on: March 26, 2010 - 07:55:52 PM »
I did this in my 2 car garage. Borrowed the bar that goes in place of the bumper and had the cart parts lying around. If you go from the bottom, after moving the torsion bars back, just remove the bolts that hold the lower ball joint to the spindle (of course the brake rotors or drums would have to come off), no alignment issues that way other than getting the ride height back to where it was.
« Last Edit: March 26, 2010 - 08:02:16 PM by ntstlgl1970 »
Offline cudazappa
« Reply #20 on: March 26, 2010 - 07:59:57 PM »
i am also in the roll it under the car camp.  made my life so easy and a lot less nervous.  When I go to a bigger small block and add a 4spd, I'll go underneath again.
2015 Dart GT - Daily Driver
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #21 on: March 26, 2010 - 09:01:31 PM »
good call I didnt think of that, just tie them up and its all good. :clapping:
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #22 on: March 26, 2010 - 09:33:54 PM »
Good idea, I don't like to disturb any rubber bushes as they can squeak if they don't go back in the original position.   :2thumbs:
Offline acudanut
« Reply #23 on: March 26, 2010 - 11:35:49 PM »
 AAR with a Big Block ?
« Reply #24 on: April 01, 2010 - 01:45:50 PM »
I did my first bottom install about 10 years ago , , I have not done it from the top since
Offline ntstlgl1970
  • T a c o c a t
« Reply #25 on: April 01, 2010 - 03:03:09 PM »
it's not an AAR, just painted that way
