Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
My Suspension Rebuild
« previous
next »
Print
Pages:
1
2
Author
Topic: My Suspension Rebuild (Read 5410 times)
Strawdawg
Resident
Re: My Suspension Rebuild
Reply #15 on:
April 10, 2010 - 07:54:11 PM »
Looks very good!
Logged
Steve
www.vortexbuicks-etc.com
bordin34
Full Member
Reply #16 on:
April 12, 2010 - 10:44:44 PM »
Today I installed new ball joints in the LCAs, a new pitman arm, a new idler arm, and new poly K-Frame bushings.
Logged
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
bordin34
Full Member
Reply #17 on:
April 24, 2010 - 12:37:42 AM »
Its all finished, all I need now is to get my new tires mounted and an alignment.
My thoughts so far are
- the car corners much flatter and surer
- my headers no longer scrape after bumps
- Much better steering response
- the 1.06" bars could be a little too much for my GR-2's but thats the best I can get
- my 1-1/8" front sway bar may be a little too much
- i desperately need an alignment
- I want some frame connectors
- I still have a popping sound when quickly cornering
Logged
BIGSHCLUNK
Sr. Resident
Miss NIKKI - were you this hot at 48?
Reply #18 on:
April 24, 2010 - 12:04:40 PM »
Congrats on the rebuild! I definetly recommend the subs - you can make them for cheap! Made a BIG diff on NIKKI! ....popping noise not good tho....
Logged
[o o o o]
OO
OO
[o o o o]
bordin34
Full Member
Reply #19 on:
April 25, 2010 - 12:15:13 AM »
The popping noise really has me stumped I checked everything over and its all tight. Also I has the same noise before the rebuild and thought it was the ball joints. I can only hear the noise I cant feel it in the wheel.
Logged
BIGSHCLUNK
Sr. Resident
Reply #20 on:
April 25, 2010 - 08:58:53 AM »
Mount on the K maybe???
Logged
[o o o o]
OO
OO
[o o o o]
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #21 on:
April 25, 2010 - 09:39:38 AM »
Describe the popping... Do you have your brakes on?...Is it one pop or several?
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
bordin34
Full Member
Reply #22 on:
April 25, 2010 - 12:28:00 PM »
It is one single pop almost like somebody tapped the frame with a hammer. If you slowly turn into the turn it doesn't do it but if you turn quickly it does. The brakes are not on and it doesn't change if they are. I changed out the K-frame and torsion bar cross member bushings with poly in the K-frame and aluminum in the cross member. I am sure the K-frame is tight but will check and re-torque the cross member.
Logged
Bullitt-
Permanent Resident
Reply #23 on:
April 25, 2010 - 01:19:06 PM »
look at your transmission mount
Logged
Huntsville, AL
bordin34
Full Member
Reply #24 on:
April 25, 2010 - 01:59:42 PM »
Really? Actually my rear one is shot. So I guess it slides side to side on sharp turns, makes sense. Will try replacing that
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
