Author Topic: Mr. Gasket Timing Tape (Small Block, Big Block)  (Read 1521 times)
Offline cwestra
« on: March 26, 2010 - 10:41:18 AM »
I can only find timing tape for big block Mopar engines.  Mr. Gasket sells a #1593 that they say is designated for 383-440 and for a 7-1/4" dia. damper.  But I believe the small block is also 7-1/4" dia.  Can anyone verify if this will work with my small block?  The only variable should be the diameter of the damper.
Corey - in Northern Indiana
Offline duodec
Re: Mr. Gasket Timing Tape (Small Block, Big Block)
« Reply #1 on: March 27, 2010 - 09:02:10 PM »
Both my NIB Mopar Performance "thin" small block damper and the original damper from my '71 318 engine are 7-1/4" diameter.  I think you are correct about the diameter of the damper being  the only relevant variable.
Offline cwestra
« Reply #4 on: April 01, 2010 - 03:54:11 PM »
Thanks for the confirmation.
