Author Topic: 440 Shortblock and Build Questions  (Read 2699 times)
Offline bordin34
« on: March 29, 2010 - 08:51:05 PM »
So I just picked up a 440 with the rotating assembly it has already been bored .030 over and I think it has .010 undersized mains. My real question is what do I need to complete this engine. All I have is the block, crank, caps, rods, pistons, and rear main seal. Also I noticed a small scratch that looks like it was done by some tool in one of the cylinders that is just enough to feel with my finger nail. Would this cause problems or should I try to hone it away first with that dingleberry thing. I have a picture of it and it looks like a crack in the picture but isn't. Also since the block has been sitting awhile it has collected some dust and dirt. What would be the best way to clean it? Should I get it hot tanked or boiled and would this ruin the cam bearing which I think I will be replacing anyway.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline 73EStroker
Re: 440 Shortblock and Build Questions
« Reply #1 on: March 29, 2010 - 10:08:50 PM »
Gee - that almost looks like a crack in the bore. If it was a scratch it would be more straight. Maybe I am seing that because of the picture.
Barry (Salmon Arm)
Offline bordin34
« Reply #2 on: March 29, 2010 - 10:20:02 PM »
Its the picture I've looked at it with a flash light really good and its just some weird tool mark that can just barely be caught with your fingernail.
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: March 29, 2010 - 10:28:46 PM »
sure looks like a crack...maybe get your machine shop to look at it  :)
« Reply #4 on: March 29, 2010 - 10:37:10 PM »
Get your block magnafluxed ASAP.
Here's a list of some items to get you started.
Stroker Kit, Muscle Motors
Machine shop short block Labor
Machine shop head labor
Gasket Teardown kit
Rear Main Seal Kit
Head Gaskets (pair)
Timing cover/Water pump gasket kit
Valve Cover gaskets
Intake Manifold Gaskets
Carburetor Air Horn Gaskets
Carburetor to manifold Gaskets
Freeze Core Plug Kit P5249708
Crankshaft Key set P524922
Oil Slinger  P5249636
Thermostat P4876307
Timing Chain
Distributor Bronze bushing
Distributor Drive Gear         P3571071
Pilot Bearing Bushing
Valve Cover Stud and Nut Kit
Valve Stem Seals                    (Viton vs. Teflon) P5249961
Valve Keepers
Valve Spring seats
Valve Sprng retainers
Valve Springs
Valve Guides
Stainless Steel
Rocker Shaft springs
Rocker Shim pkg.
Rocker Shaft End Plugs
Head Bolt hardware
ARP assembly lubricant 100-9909
Oil Pump Bolts
Oil Pump, High PSI
Oil Pump Pick Up Tube
Windage Tray
Cam Bearings
Connecting Rod Bearings
Main Bearings
Lifters
Camshaft
Ignition Wire set
Paint Supplies
Engine Paint, Acrylic Enamel
Power Steering Pulley
Crank Pulley
Alternator
Water Pump pulley
Engine Oil Dip Stick
Re built Carbs
Oil Pressure Sending Unit
Oil Pressure Sending Unit Heat Shield
Heater Hose Outlet Block Nipples
Flywheel Bolts
Exhaust Manifold Bolts
Carb Linkage Shoulder Bolt
Alternator  head mounting bolt
Carb Inline Fuel Fittings
alternator Bracket Spacer Kit
Carb Spring Set
PCV Valve
Wire Separator Bracket
Alternator Pulley
Throttle Cable Bracket
Fuel Line Set
OEM Hose clamp set
Timing Bolt set
Water pump housing bolts
neg. battery block bolt
Exhaust Pipe Bolt Set
Oil Pan
Electronic Distributor
Distributor Cap
Distributor hold down bolt
Throttle Cable
Federal Power Steering
Shaker Baseplate
Mopar Fan clutch
Fan clutch Rebuilt service
Air Cleaner Lid
Air cleaner to carb Studs
Starter Cable bracket on Bell Housing
Water Pump Housing
Exhaust Manifolds  or headers
Power Steering Return Hose
Carb Idle mixture caps
Power Steering Cooler
Upper Radiator Hose
Hemi Choke
Water Pump
Belts
Coil
PCV breather
Flywheel
engine mounts
positive battery cable
Ignition valve cover grommets
Engine Wire harness
Offline bordin34
« Reply #5 on: March 29, 2010 - 10:40:33 PM »
I just checked again and it is definitely a tool mark, you can even see where the tool hopped and didn't make as deep or any mark in places.
« Reply #6 on: March 29, 2010 - 10:42:49 PM »
get it magnafluxed anyway regardless of what the mark is. An engine is no place to take shortcuts. Probably a couple hundred bucks to get done.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #7 on: March 29, 2010 - 11:01:59 PM »
That my friends is a crack.
Don
Member Since January 14, 2002
Offline moper
« Reply #8 on: March 30, 2010 - 11:36:40 AM »
Cant see the pics, but a magnaflux is the only way to know about an unknown block. Regardless of appearance.
Offline 4 speed fish
« Reply #9 on: March 30, 2010 - 01:00:18 PM »
Great list Mike.Did you list the fuel pump push rod?
Offline bordin34
« Reply #10 on: March 30, 2010 - 05:35:30 PM »
Thanks for the list, I'll probably get it magnafluxed just to be sure.
Also I am going to be raping my current 400 for some parts, but not many I still want it to be sealed so its internally clean.
I will be taking
The rocker arms and shafts
All the pulleys and accessories that fit
Timing Cover
Distributor hold down bracket and bolt
And probably some misc. little parts
Offline moper
« Reply #11 on: March 30, 2010 - 06:14:18 PM »
Now that I can see it...That's what a crack looks like...
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #12 on: March 30, 2010 - 08:11:42 PM »
You can buy a Magnaflux kits for much less than a couple of hundred bucks. Or take it to a machine shop and get it MT'd. Magnaflux crack check dye penetrant is a 3 part process and the kits come with 3 cans: cleaner (which is nothing more than acetone or isopropyl alcohol, penetrant (a red colored dye) and developer (a white powered substance). The surface is cleaned with the cleaner (make sure it's VERY clean; no grease or dirt), then sprayed with penetrant dye, whiped thoroughly dry and then sprayed with developer. IF there is a crack, it will show up as a thin red line. If not, no lines! I just purchased a crack finder kit from Silver Seal for about $45 bucks plus shipping. I had overheated a Bosch aluminum engine and blew a head gasket. I of course had to check the block and heads for cracks and used the kit. Magnaflux is expensive and an identical product such as the one made by Silver Seal is much cheaper. You can do a Google for "dye penetrant" or Google "Silver Seal" to get to the web site. An invaluable tool for engine builders!! It's very easy to use and requires no special tools. just follow the instructions. Good luck & i hope it's not a crack!! :2thumbs:
                                            Matt B.
Matt
« Reply #13 on: March 30, 2010 - 10:11:40 PM »
If it is a crack, (which it looks like) it can be repaired.
Offline bordin34
« Reply #14 on: March 30, 2010 - 10:31:39 PM »
Thanks, I figure worst case I could probably get that cylinder sleeved and still be ahead for what I paid. But I really do not think it is a crack you can see where it starts and stops a couple times from what I think is the tool skipping and it looks wider than a crack.
