Did anyone ever come up with a definitive answer as to whether I put the springs on the right side or not??? The one with more leafs towards the front of the spring (ie directly in front of the ubolts I count 6 leafs, and directly behind the ubolt I count 4) is on the passenger side, and on the drivers side I count 4 leafs directly in front of the ubolt and 5 leafs directly behind the ubolt, (part numbers ending in 65 on the right, 66 on the left), as the mopar and mancini catalogue said to do, does this seem right??? This should mean that the passenger side would sit a bit higher wouldn't it? And isn't that a common trait of superstocks, a little higher on the passenger side? I understand that usually the even part numbers go on the right (passenger side) but not for my application according to part numbers, so if it is a part number mix up shouldn't I be able to count the leafs to figure it out? The part numbers, etc are listed a little further back in this thread. Thanks for the help guys, I know it sounds a little confusing, I hope you can make sense of it. Tyler
