Author Topic: Experienced CLEARANCE Problems WITH MILODON HV Oil Pump in a ALTERKTION SET UP?  (Read 1423 times)
Offline EbodyPro572
  • "Always restore, NEVER discard!"
I'm considering using the MILODON H/V Aluminum Oil pump w/external oil lines on my 572 aluminum Hemi in my 73 Challenger instead of the Mopar OEM pump.
Is anyone aware of any clearance problems with the ALTERKTION sub-frame OR MOTOR MOUNTS???????
I want to use the MILODON PUMP if there are no hassles.  If not, I'll go with the OEM pump.
Any help or guidance is greatly appreciated!!!!!!
Thanks,
« Last Edit: March 31, 2010 - 04:45:43 PM by eBodyBliss »
'ALWAYS Restore.....NEVER Discard'
73 Challenger; 04 Rumble Bee (Yello, of course); 01 Vehicross (Yello, of course, too); 90 Allante' (not Yello, just red); 79 MGB-V8; 68 Century Resorter;
73 Marlin Ski (468" Olds) Jet Boat; 06 Harley Fat Boy CVO; 73 Yamaha Golf Cart (Yello, of course); 07 Sears Garden Tractor
Offline efidart
The Hemi mounts will interfere with the milodon cover not the pump, I ended up grinding the cover and welding it to make it clear. I will see if I can get you some pics today.
72 Dart - Precision 114mm Pumpgas 572
73 Cuda - 340 6 pack
Offline EbodyPro572
I'd be super happy if i could use the milodon pump.  You didn't say it, but i'm assuming you also used the alterktion front end?  Bill Reilly at Reilly MotorSports said basically the same thing that the cover was the issue and not the pump itself.  IF YOU HAVE PICS that would be great!!!!!!
Thanks so much, Scott in Michigan
Offline ntstlgl1970
  • T a c o c a t
tubbed 440 had a milodon setup for sale, I think he mocked it up in his car with the alterkation. he has a thread in the restoration forum.
Offline EbodyPro572
THANKS ntstlgl1970!
I'll check it out.  Scott
