Author Topic: Steering Gear... Final Chapter...................................?  (Read 17307 times)
Offline BIGSHCLUNK
Re: Steering Gear... workin' the JIGSAW PUZZLE
« Reply #45 on: June 08, 2010 - 11:31:06 PM »
Hey I made it back out to the garage tonite! (briefly) Worked on getting the colum back in, had to call the wife out to give me a hand . I had a helluva time getting the coupler on the box! It took a week bit of tapping , which I didn't want to do.  :nono: Actully poped the top off the coupler.  :banghead: Got the roll pin back in, everything else just has nuts and bolts on by a thread or 2. Stuch the centerlink back up, just a few threads too!. Hopefully everythings lined up ok.  :dunno:  Most likely will find out later this week, too much to catch up on since I came back from Florida. Keepin' my fingers crossed......
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
« Reply #46 on: June 12, 2010 - 01:16:30 AM »
Made some progress tonite!!  :woohoo: Colums back in, couplers back together, centerlinks tight! And NO dumazz my wheels upside down or I can only turn rt 3/4 of a turn...  :bananasmi    :bananasmi   :bananasmi
http://s672.photobucket.com/albums/vv82/BIGSHCLUNK/Steering%20Gear%20II/?action=view&current=SteeringGear9009.jpg
It was soooo humid in the garage my oil pan was sweating!
« Last Edit: June 12, 2010 - 01:20:21 AM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Steering Gear... Colum's back in!
« Reply #47 on: June 12, 2010 - 09:25:54 AM »
AHH...Ready Fer NASCAR Racin  :biggrin:
Offline BIGSHCLUNK
« Reply #48 on: June 12, 2010 - 09:52:41 AM »
Wade, didn't even think of that.... valid tho...  :roflsmiley:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
« Reply #49 on: June 12, 2010 - 09:23:30 PM »
Got lots done today...
Got all my Cables and wiring plugged back in
Got the new P/S pump and lines installed
Got rid of that POS leaky Tiwan therm housing  :bananasmi
Got the battery tray in... POS chinese... it fits now that I took the dremel too it... of course already painted!!  :banghead:
Lubed up EVETYTHING, did a primary fill on the rad the p/s pump
Changed oil, hey she was up in the air anyway... BTW BIGS recommends WIX  :2thumbs:
Thought I'd spin her over(not start) just to start some new fluids circulating , do a prelim leak check........................................................................................
no freakin crank  :swear:  :swear:  :swear:
jump the relay cranks fine...  :banghead:  :banghead:  :banghead:
screwed up something....  :faint:
time for a beer  :cheers:
http://s672.photobucket.com/albums/vv82/BIGSHCLUNK/Steering%20Gear%20II/?action=view&current=SteeringGear10002.jpg
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Steering Gear... Lots done today... but...........................
« Reply #50 on: June 12, 2010 - 09:29:38 PM »
Column connectors together nice and tight? :popcorn:
« Reply #51 on: June 12, 2010 - 09:42:31 PM »
Sure she's in Park ? ...Try Neutral  :popcorn:
Offline BIGSHCLUNK
« Reply #52 on: June 12, 2010 - 10:10:06 PM »
haven't tried it in neutral... but thats the first thing on tomorrows list. Colum connecters all good, my neck still hurts from double checkin'. Weird.... never had a "no crank" w her long as I owner her.  Didn't mess with shifter /neutral switch at all. Made no linkage adjustmnents. Even swapped start relays (but really didn't think that was the prob). Got the test light "on" at the I terninal when I hit the key...   :pullinghair:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #53 on: June 12, 2010 - 10:32:53 PM »
Don't know what your testing, but it would not be the 1st time a new part was bad...sure the brown ground wire is on?
Offline BIGSHCLUNK
« Reply #54 on: June 12, 2010 - 10:45:18 PM »
testing for switched hot. Yes brown wires on...  Been playing the senario in my head... I dont think I forgot to plug in anything,  :eek4:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #55 on: June 13, 2010 - 11:30:56 AM »
If the test light comes on at the relay when you turn the key, try connecting the brown ground terminal straight to the negative on the battery. If it starts then its is the nss wiring and or linkage adjustment. If it doesn't turn over, it's the relay.
Offline BIGSHCLUNK
« Reply #56 on: June 13, 2010 - 12:50:08 PM »
The prob appears to be somewhere in the adjustment of the rod going to the arm on the bottom of the column. When I play with it I can get her to crank. Seems as if the column did not go back in "exactly" the same spot where I took it out of. Also when the key is "off " I shouldnt be able to take her out of park should I?? I can almost make it to neutral. Gotta go play a little more. Didn't BARRY have some thing on this awhile back??
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #58 on: June 13, 2010 - 12:59:47 PM »
Looks like an adjustment at the "swivel" bottom left
Offline BIGSHCLUNK
« Reply #59 on: June 13, 2010 - 01:07:06 PM »
Thats what I'm playing with right now , gotta be right "in there someplace" . Thanks for the link WADE!! Wi-fi almost makes it to the garage!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
