Author Topic: Parking brake cable  (Read 706 times)
Offline txchallenger
Parking brake cable
« on: April 02, 2010 - 11:34:20 AM »
Does someone have a photo of underside showing the way to hook up the parking brake cables. This is on a 72 Challenger and I have installed subframe connectors so I know I will have to drill for the cable from the foot petal. I just don't know where the threaded rod or the "s" hook go.
Thanks
Greg
Re: Parking brake cable
« Reply #1 on: April 02, 2010 - 12:37:36 PM »
If you're going US Cartool connectors, here's mine.
« Reply #2 on: April 02, 2010 - 01:55:02 PM »
Exactally what I needed !!!
Yes I'm using the UScartool  connectors
Thanks Topcat !!! :thumbsup:
« Reply #3 on: April 02, 2010 - 03:22:31 PM »
I put in stainless steel tubes on each side. This way the cables won't get chaffed as much. You'll need to drill a straight hole, then use a flame head shaped carbide burr grinding tool to make it a 45 degree hole. The tubes I bought at ACE hardware.
The reason why (Ask me how I know) is that trying to drill at a 45 degree angle will break off the drill bit.
Offline Ornamental
  • Oslo, Norway
« Reply #4 on: April 22, 2010 - 04:07:27 PM »
Do you have any photos with the exhaust and drive shaft installed?
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
« Reply #5 on: April 22, 2010 - 10:21:11 PM »
No
Haven't painted under side yet. The holes are up high as you can see in the close up pic so everything should clear easily.
