Author Topic: Carpet  (Read 645 times)
Offline RUSTY Cuda
  • One big step foward!
Carpet
« on: April 02, 2010 - 12:41:54 PM »
Workin the rear section need some advice.
K, laying out the carpet, they say it's larger than I need but I'm getting paronoid about cutting it short so here's a few questions for you guys!
1st I made some slices around obsticles & then I froze
Need to know how much I leave over the doorsils to be secure under the sil plates & where to cut it(at front & rear of the plates) & around the area where it meets the quarter panel interior trim.
front & rear carpet overlap quite a bit which one do I shorten quite a bit so it's not double under the sil plates(or can I leave it double(seems a BIT thick to leave both) & still get the plate flush.
Is there a way to kinda put a slice in it so it lays in good where it comes up from the floor pan to the rear quarter areas when you press in it pulls the topstuff in a bunch.
Now if any of that was clear to you your a better man than I, all hints & suggestions appreciated!  Rich.
« Last Edit: April 02, 2010 - 12:43:44 PM by RUSTY Cuda »
Re: Carpet
« Reply #1 on: April 02, 2010 - 10:07:09 PM »
I usualy leave about 1" over the body seam under the sill plates , I trim the lower carpet off & use the upper /front carpet to hold it down , I trim it close to the body seam behind the kick panels & leave it up about 1.5" behind the kick panels , I have never sliced it in the rear between the floor up under the rear seat, if it is molded correctly it should sit in there well
Re: Carpet
« Reply #2 on: April 02, 2010 - 10:19:35 PM »
Wait to trim the sides until all the interior is in, seats & belts, that took up some slack in mine.
Offline RUSTY Cuda
Re: Carpet
« Reply #3 on: April 02, 2010 - 11:18:14 PM »
You guys are good, I did get the seat belts in the drivers side & then laid out the front & made my cuts & slices around the shifter, hope I have it close , now I'll work my way out to the sides, I put my seat belt wires under the carpet(made a small hole under the retactor) Now I have to see if it reaches the pass side one, looks like it's gonna be close.
I ment slicing the high part so it will bend over the top easier, I may hvae to adjust the outside seat belt hole a little, it seems more wadded up than it did before, I'm close I'll keep tweekin it.
hard to see in the pic but this is that back corner & my cuts by the shifter.Thanks,Rich.
