Hey Guys,
I started off with no taillights. I got he t/s switch and did the quickie plug in, and now have lights. Since I have to pull the steering wheel, I thought I may as well as replace it with a tuff wheel. And as long as I am replacing the wheel, I may as well get the horns working. I do not have a horn relay plugged into my fuse block. I think that is where it should be. I ordered one from year one for a 71, but they sent me a relay with 3 terminals on one side, and nothing on the other like the fuse block takes and it has a bracket welded to it. It does not look like a 70. Does it need the fourth terminal? If so, I cant find one very easily. Does anyone have a lead for me to follow up to get something that will work? I plugged the year one relay in, but no horns. I did test the horns off of the battery with positive results. I didn't do much investigation of the wires since I still don't have the correct relay (maybe?). Any help for the newbie? Thanks
