Author Topic: Header Advice  (Read 1372 times)
Offline vpittman
Header Advice
« on: April 03, 2010 - 06:59:21 PM »
Hi all,
I'm restoring a '73 Cuda, with a '76 360... nothing perfect or anything but hope to have a really nice driver.
The headers are a bit rusty so I pulled the off today. It seems the headers I have are Patriot H8205...
It will cost me $225 to have these ceramic coated, it it worth it ? I could try to coat them myself or possible buy a new set...
What do ya'll think ?
Thanks !
Re: Header Advice
« Reply #1 on: April 03, 2010 - 11:08:37 PM »
do they fit well , do they go under the steering link ?
are the dented ?
 Need more info , if they go under the steering I would replace them or if the fit is bad , most headers limit access to the 5&7 plugs, Dougs & TTI are better but will cost you more
Offline GoodysGotaCuda
Re: Header Advice
« Reply #2 on: April 03, 2010 - 11:13:46 PM »
I,like many have the headers that go under the steering link. I would certainly not dump a dollar into a set of headers that go around the link. I will be spending good money on headers that don't drag the ground next time.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Header Advice
« Reply #3 on: April 03, 2010 - 11:19:34 PM »
You can get a new set or Patriots already ceramic coated for $330...don't think I'd bother coating to old ones....how did they fit?, maybe just clean em up & paint....
I put the cheaper Hooker Competition model on, biggest problem is they do have the pass through steering linkage which costs ground clearance, other wise no fitment issues...2-plugs are a pain as CP pointed out.
Offline vpittman
Re: Header Advice
« Reply #4 on: April 04, 2010 - 12:06:25 PM »
Yea, these are shorties so they don't go under the linkage, not dented and fit good, as far as I can tell...
Thought about it a bit last night and I'm just gonna paint them for now and get a set of Hooker Super Comps later
Thanks for all the help
Offline shadango
Re: Header Advice
« Reply #5 on: April 05, 2010 - 12:26:27 PM »
I just have to throw a plug in for Dougs....
LOVE mine.
I balked at first about the extra cost....but ease (relative) of install, look, sound and clearance have me very happy....quality is awesome and I have never looked back on that purchase and second guessed it.
Offline moparmaniac59
  • Drive it like ya stole it!
Re: Header Advice
« Reply #6 on: April 05, 2010 - 12:31:26 PM »
 :iagree: I too have Doug's and couldn't be happier although I can't advise on small block fitment as I have a big block, but the fit and quality are superb. I think the only better would be TTI and they do cost more than Doug's.
                                                       Matt B.
Matt
Offline vinb
Re: Header Advice
« Reply #7 on: April 05, 2010 - 06:22:19 PM »
Hooker Super Comp's #5115, best fitting header on a small block 'Cuda without doing a custom set..
1 3/4" tube,  3" collector, 35" long..
With or without power steering , Auto or 4spd... #5 & #7 plug wires no problem, don't need a oil filter adapter either...
No complaint's here, both sides OVER the drag link....
Offline vpittman
Re: Header Advice
« Reply #8 on: April 05, 2010 - 09:26:39 PM »
That's what I've read elsewhere here... so is it worth the extra to get the ceramic coated ?
Offline TROUBLE987
Re: Header Advice
« Reply #9 on: April 05, 2010 - 09:47:30 PM »
                                                       Matt B.
hey matt how is the coating holding up?did you have to beat on them any?
Offline Road_Runner
Re: Header Advice
« Reply #10 on: April 05, 2010 - 11:59:47 PM »
Absolutely, I wouldn't buy another set of uncoated headers for any amount of money.  I couldn't stand the way headers immediately rusted back in the 70's and how they generally rusted through in 4-5 years.  I've had a set of coated Hookers on my Roadrunner for over 10 years and although they've dulled a bit they otherwise still look like new.  No comparison.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline smallblocksrock
Re: Header Advice
« Reply #11 on: April 06, 2010 - 12:17:04 AM »
I have Doug's headers on a 318/904 73 Barracuda and a 340/4 speed 70 Challenger.  They fit great.  I did not need to "massage" any of the tubing to make them fit.    You have to use a mini-starter, but you can install it with the headers installed.
Offline shadango
Re: Header Advice
« Reply #12 on: April 06, 2010 - 08:24:08 AM »
I wasnt able to install the ministarter I got with the header installed  (318/727)....have to loosen it.  :swear:
Re: Header Advice
« Reply #13 on: April 07, 2010 - 12:11:39 PM »
The coating looks fine. Like it did when I installed them. No beating involved although they are very close to the power steering pump.
                                                 Matt B.
Matt
Offline TROUBLE987
Re: Header Advice
« Reply #14 on: April 09, 2010 - 03:58:29 PM »
                                                 Matt B.
thx for the info...that will be my next set then!!!
