Author Topic: rear glass chrome moulding clips  (Read 5855 times)
Offline barryv
« on: April 04, 2010 - 08:00:43 PM »
hi,can someone tell me correct number of pins around rear window frame that trim clips go on.closeup picture of location of clips would be very helpful,thanks
« Last Edit: April 04, 2010 - 10:49:31 PM by barryv »
Offline ntstlgl1970
  • T a c o c a t
Re: rear gass chrome moulding clips
« Reply #1 on: April 04, 2010 - 08:45:47 PM »
I don't have a close up but this should be the correct number of clips, mine was a vinyl top car, not sure that makes any difference.
Offline barryv
« Reply #2 on: April 04, 2010 - 09:13:25 PM »
mine was vynl as well it looks like you have 22 clips is that correct,thanks barry
Offline ntstlgl1970
  • T a c o c a t
Re: rear glass chrome moulding clips
« Reply #3 on: April 05, 2010 - 03:04:54 PM »
That is how many mine came with. hopefully someone else will have a better picture.
Offline barryv
« Reply #4 on: April 05, 2010 - 08:56:37 PM »
thanks for your help
Offline Chlngrcrzy
« Reply #5 on: May 19, 2010 - 09:32:14 PM »
My kit came with 21 clips and screws. I hope someone can come up with some close up pictures.     :-\
Offline 67vertman
  • Member since 9-23-2005
« Reply #6 on: May 19, 2010 - 10:22:19 PM »
There are not any "set" locations for the clips and they differ slightly from car to car.
ntstlgl1970 picture show how many on top anh how many were on the sides and top.  Place you trim around the opening and mark were they come together, as you do not want a clip to sit exactly were the come together.  other than that just space them evenly around the window and you will be good to go.
Offline Chlngrcrzy
« Reply #7 on: May 19, 2010 - 11:47:33 PM »
Does the clip sit all the way down against the window lip?
Offline 67vertman
« Reply #8 on: May 19, 2010 - 11:58:57 PM »
Mine do. The top of the clip sit almost even with the top of the body, only about a 1/16th of an inch above the window frame.
Offline dutch
« Reply #9 on: May 20, 2010 - 03:11:55 AM »
*** Bart ***
