Author Topic: 72 grill trim clips?  (Read 1463 times)
Offline shadango
« on: April 05, 2010 - 11:30:09 PM »
On the 72 grill, there are the two large rings that are trim...one for each half of the grill....made of stainless or aluminum......they mount with 4 spikes that push through what I assume are clips of some sort....
Can someone give me a name on what to call these so I can try and find some?   seems that they are loose on my grill...almost lost one of the rings today!  :22yikes:
for now I put a glob of silicone on two of the spikes just to keep it from falling off...the grill is on the car so tough to see, but I think they are very small clips.
Anyone know?
Offline UKcuda
  • Tell them I'm on my way
Re: 72 grill trim clips?
« Reply #1 on: April 06, 2010 - 02:24:21 AM »
Yeah those clips are tiny little square fellas.  Don't know where to get them.
I think the chrome trims should have six pins, not four.
The clips will hold it loose if the pins are worn.  On my car I used some short lengths of rubber tube with "gripfill" in them pushed on from the back - so far they are holding it nice and firm.
'72 'cuda
Offline shadango
« Reply #2 on: April 06, 2010 - 05:24:56 AM »
I like the rubber tube idea.....just have to fond something small enough that will hold firm yet push on by hand,.....
What's "grip fill" ?? :clueless:
Offline UKcuda
« Reply #3 on: April 07, 2010 - 05:08:32 AM »
"Gripfill" is a filler/adhesive in a tube like a mastic sort of thing, it sets into a plastic.  It was the nearest thing to hand.
I decided to glue the tubes as extra insurance as I'm unlikely to need that trim off again and I figured the more secure it is the better.  If I do need it off I can easy cut the tubes away with a sharp knife .
The tube I used was much like you see for vacuum pipes in the engine bay, it has quite a thick wall and narrow inside so it goes on nice and tight.
'72 'cuda
Offline shadango
« Reply #4 on: June 16, 2010 - 08:34:59 AM »
As a followup --  I finally got around to painting my grill.
Found the cips on ebay and online, but ridiculously pricey so I guess I will try your rubber tube idea.....just have to find the right size I guess...do you recall the ID size by chance?
Offline UKcuda
« Reply #5 on: June 27, 2010 - 05:03:16 AM »
It was a couple mm or so.  As I say, like old shool vacuum accessory tubing.  I looked at mine the other day, it still seems tight on there.
'72 'cuda
Offline shadango
« Reply #6 on: June 27, 2010 - 08:47:46 AM »
Thanks...
I just ended up using a small glop of clear silicon on each one....seems to be holding fine so far.....
