Author Topic: 8 3/4 rear end  (Read 1110 times)
Offline kmyles
8 3/4 rear end
« on: April 06, 2010 - 03:03:36 PM »
Is it possible to get or build a diff with 321 gears?
I have a chance to buy one and the guy swears its a posi out of a 8.75. No carrier just the clutch sg with the gears. What should I look for?
« Last Edit: April 06, 2010 - 03:07:32 PM by kmyles »
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline ChallengerHK
Re: 8 3/4 rear end
« Reply #1 on: April 06, 2010 - 03:05:34 PM »
3.23 is a pretty common ratio and there shouldn't be a noticeable difference between the two.
- Han Solo, Star Wars
Offline kmyles
Re: 8 3/4 rear end
« Reply #2 on: April 06, 2010 - 04:17:34 PM »
So you can get a 8.75 with 321? How can I be sure it,s for a 8 3/4?
_________
Kevin
Re: 8 3/4 rear end
« Reply #3 on: April 06, 2010 - 04:26:52 PM »
no 3.21 ratio in a 8 3/4 ever , possibly an 8 1/4 carrier with 3.21 gears
Offline kmyles
Re: 8 3/4 rear end
« Reply #4 on: April 06, 2010 - 04:34:05 PM »
Is there a number or something stamped on it to verify? There has to be someway of telling if it's for a 8 3/4.
_________
Kevin
Re: 8 3/4 rear end
« Reply #5 on: April 06, 2010 - 05:35:44 PM »
measure the ring gear diameter
Offline kmyles
Re: 8 3/4 rear end
« Reply #6 on: April 06, 2010 - 05:43:24 PM »
One of the sg's dosen't have the ring and pinion. Is there a way to tell on just the sg?
_________
Kevin
Re: 8 3/4 rear end
« Reply #7 on: April 06, 2010 - 05:46:22 PM »
you could measure the ID of the ring gear / OD of the sure grip but I don`t have one here to get a mearsurement from
Re: 8 3/4 rear end
« Reply #8 on: April 06, 2010 - 07:07:08 PM »
Should be 12 bolts holding the ring gear on to the sure grip.  and left hand thread, but I think most are.
