Author Topic: Horn relay Whats its purpose?  (Read 4280 times)
Offline DocMel
« on: April 06, 2010 - 09:46:38 PM »
If the horn works without a horn realy, why use one at all?   Whats the purpose of a horn relay/how does it work?
Offline 71chally416
    • The Streetwalker
Re: Horn relay Whats its purpose?
« Reply #1 on: April 06, 2010 - 09:56:46 PM »
It's there so at some point it malfunctions and the horn stays on making you look like a total ass.  :bricks1:
Offline GoodysGotaCuda
« Reply #2 on: April 06, 2010 - 10:11:08 PM »
The horn relay (or any relay) usually acts as a high current switch that can be controlled by a low current signal.  The signal in this case, is you pressing the horn button on the steering wheel.  The small current signal from the horn button is sent to the relay via a small gauge wire.  This closes the relay switch which allows a much larger current to flow from the battery through heavier gauge wires to the horns themselves.  Hope this simple explanation helps some.   :2cents:
Yep, keeps high current from also hurting the bearings in the column and burning the contacts out on the horn button
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #3 on: April 09, 2010 - 04:36:41 PM »
HORN botton is the ground for the horn relay.
Offline UKcuda
  • Tell them I'm on my way
« Reply #4 on: April 09, 2010 - 05:50:44 PM »
Quote
Partial yes.
Please someone correct me if I am wrong, but I believe the only reason they fitted a relay on the horn was to protect the steering column bearings - they didn't put a relay on anything else!
'72 'cuda
