Author Topic: Trunk divider  (Read 1443 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
Trunk divider
« on: April 06, 2010 - 11:22:58 PM »
Ok, Just got a new trunk divider for my Challenger and hope to install it tomorrow. I wanted to ask, I got the insulation that Legendary offers with the divider. What do I do with it? Does it need to be glued to the board? Do I leave it hanging on the seat hooks? Also does it go on the inside of the cabin or facing the trunk side?
Re: Trunk divider
« Reply #1 on: April 07, 2010 - 10:18:05 AM »
it goes inside under the seat back
you can glue it or just hang it under the seat
Re: Trunk divider
« Reply #2 on: April 07, 2010 - 12:49:31 PM »
Your the man!!!   :cheers:
Offline gcbeeper
Re: Trunk divider
« Reply #3 on: August 18, 2010 - 10:23:51 AM »
Does the divider have any screws or bolts to hold in place or is it just the hangar? Also, if I am installing dynamat on the divider and package tray, is the insulation needed at all?
Thanks
Re: Trunk divider
« Reply #4 on: August 18, 2010 - 11:27:24 AM »
Thanks
The trunk divider just hangs on those two hooks. The insulation isn't needed, but it can't hurt.
EDIT: In those locations, the insulation is more for keeping the cold air out, so I'm not sure how much an inch or so helps, but I put it in mine.
« Last Edit: August 18, 2010 - 04:19:23 PM by MEK-Dangerfield »
