Author Topic: 440 transplant.  (Read 6254 times)
Offline mopar12372
    • mopartech
Re: 440 transplant.
« Reply #30 on: May 20, 2010 - 01:10:46 AM »
good for you !!  :thumbsup:
RESTO PICTURES
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
Re: 440 transplant.
« Reply #31 on: June 04, 2010 - 04:26:37 PM »
Motor is coming along slowly. I need to buy some head studs to bolt heads down now. Also a couple of black wrinkle finish rocker covers  :bananasmi The $$$ just keeps flowing out the door  :ylsuper:
Re: 440 transplant.
« Reply #32 on: June 04, 2010 - 05:02:33 PM »
I don't think that will fit under the hood.    :lol:
Offline mojavered
  • Someday!
Re: 440 transplant.
« Reply #33 on: June 04, 2010 - 05:03:08 PM »
Looks good!  Is that air cleaner going to stay on?  Why do you need head studs?  What is wrong with head bolts.  I think I remember hearing that it is better to run head bolts on a street application.  I think it was something to do with not being able to remove your head when the engine is in the car.
Jason
Offline punisher72
Re: 440 transplant.
« Reply #34 on: June 04, 2010 - 05:18:59 PM »
The air cleaner was put there by the mechanic to look good  :clapping: Im told the studs hold way better and more accurate than bolts?? I would rather stay with the bolts to save $$$$$ Im just going on the mechanics recommendations.
Offline mopar12372
    • mopartech
Re: 440 transplant.
« Reply #35 on: June 04, 2010 - 06:35:05 PM »
with the hp your engine will be makeing the studs are over kill, arp bolts will work for a long time and alot less money. 440 source has bolts that are ARP they re alot less and dont come with the stickers wich make the price less. just my 2c
RESTO PICTURES
Offline punisher72
Re: 440 transplant.
« Reply #36 on: June 05, 2010 - 01:09:16 AM »
Im fairly keen to spend less. Could i just use the head bolts i have an not buy any??
Re: 440 transplant.
« Reply #37 on: June 05, 2010 - 07:09:02 PM »
I would not run head studs in a street engine , you cannot remove the heads easily
Offline mopar12372
    • mopartech
Re: 440 transplant.
« Reply #38 on: June 06, 2010 - 10:28:52 PM »
no, stock head bolts will not fit eddy heads . 440 source sells a noname head bolt thats ARP with out the packageing just doesnt come with the stickers and box.
RESTO PICTURES
Offline punisher72
Re: 440 transplant.
« Reply #39 on: June 07, 2010 - 03:10:46 AM »
Thanks for the advice guys. I questioned my mechanic about head bolts and he was real keen on the studs! So i thought well hes building it so i will go with what he wanted...... I should have the arp studs here tomoz as they are coming from Sydney. :thumbsup: Yes they did cost a lot,but i do feel better going that way :cheers:
Offline mopar12372
    • mopartech
Re: 440 transplant.
« Reply #40 on: June 07, 2010 - 09:07:57 PM »
the studs are a great investment , just might have to remove the engine to get the heads off .
if every thing goes as planned youll have a great engine to play with
RESTO PICTURES
Offline punisher72
Re: 440 transplant.
« Reply #41 on: June 08, 2010 - 02:19:08 AM »
 :bigsmile: I cant wait to bolt it up to my 4 speed an drop the clutch..... :burnout: :2thumbs:
Offline mopar12372
    • mopartech
Re: 440 transplant.
« Reply #42 on: June 08, 2010 - 08:20:46 PM »
just make sure when you drop the clutch that the revlimiter is working.
RESTO PICTURES
Offline punisher72
Re: 440 transplant.
« Reply #43 on: August 26, 2010 - 05:37:47 AM »
Hi everyone. Ive been reading up and talking to a few guys about the oil side of my motor. For best oiling i should drill out the pick up hole in the block to 1/2 inch and fit a high volume pump. Im also concerned about the standard sump having enough oil to keep up?? I plan to drag the chall a few times a year and have lots of fun on the streets. The motor is together which is a bummer for drilling!!
Anybody have any ideas???
Offline 72cudamaan
Re: 440 transplant.
« Reply #44 on: August 26, 2010 - 08:39:52 AM »
FWIW, Tear it all down and drill for the pickup, but with a close to stock motor I wouldn't think that you would benefit too much from this mod. I would not tear the motor down if it was me.  :bigshades:
If I cant fix it, it's broke
Andy  (phukker whither)
