Author Topic: * HELP * My .318 will no longer turn over!!!  (Read 1147 times)
Offline cv70chall
  • 1970 Challenger
« on: April 07, 2010 - 12:59:32 PM »
Hi everyone-
I have an issue with my project that I hope I can get some guidance with.
I have a 70 Challenger with a 318 that has been in the shop for the past 3 years getting restored. It's been a long drawn out process- as we came across things that we decided to replace one after the other.
The car ran fine when we started and was obviously driven at all whilst in the shop. We recently completed the body work and tried to turn the engine over with no luck. New battery- starter checks out fine- and we inspected the motor/ cylinders and found no evidence of any water or moisture. When we try to turn it over, we get a click. When we try a pry bar to move her, we get little if any give (motion).
Any ideas on what we can check? This vehicle has been indoors being worked on and there should not be any issue with seizure.
*** HELP!! ***
Any ideas, tips or witchcraft I might be able to try???
It hurts to get this close to being "done" and have this happen.
Thanks!
Chuck
561-603-6103
Offline 360 'CUDA
Re: * HELP * My .318 will no longer turn over!!!
« Reply #1 on: April 07, 2010 - 01:18:14 PM »
Can you turn the crank by hand?  Put a breaker bar and socket on the front of the crank, it should move easily. If not it's an engine problem
 If it's a electrical problem check the battery cable ends and the wires connections on the relay.  Does it turn over when you jump the relay with a screwdriver?
If it does the problem might be the ignition switch in the column
Check out the fusible link and tighten up the screws on the relay.  The fusible link is problematic and needs to have clean connections
I'm just guessing but these are the things that go bad first
« Last Edit: April 07, 2010 - 01:21:06 PM by 360 »
Offline 72bluNblu
« Reply #2 on: April 07, 2010 - 01:20:09 PM »
A "click"?
Usually that means one of the following-
1. Insufficient voltage to run the starter (drained/bad battery)
2. Bad solenoid
3. Bad starter
4. Bad/loose connection to any of the above
Has the battery (even though its new) been sitting for awhile? If it has it may have sulfated, even new batteries can do this if not charged one way or another for a few months.
Offline dodge freak 2
« Reply #3 on: April 07, 2010 - 01:23:58 PM »
Welcome to the broken motor club :'(
You sure you are trying to turn the motor by using the crank bolt, its the only sure way.  Takes a lot with the spark plugs in.
Was there enough oil in it. My brother used to be an "expert" on locking motors up by running them dry. Doesn't take long at all for one bearing to freeze up
Offline cv70chall
  • 1970 Challenger
« Reply #4 on: April 07, 2010 - 01:35:40 PM »
We tried turning the crank...No luck.
Plenty of oil in the motor- NO water in the cylinders- no evidence of moisture anywhere.
Fuseable links/ connections/ starter solenoid/ starter are all good.
Brand new battery in the car.
We're letting it sit with some PV Blaster in the cylinders and we plan on trying again tomorrow. Someone said to try vinegar in there?
Any other ideas? This just does not make sense...
Offline 360 'CUDA
« Reply #5 on: April 07, 2010 - 01:45:26 PM »
Maybe someone in the shop took it out for a little fun before the restoration began??
Offline cv70chall
  • 1970 Challenger
« Reply #6 on: April 07, 2010 - 01:54:37 PM »
I wish that was the case! LOL.
« Reply #7 on: April 07, 2010 - 02:29:25 PM »
Hmm, I PM you before reading this. Yeah the spray oil in the cylinders might do it.
Kind of doubt a bearing froze up just sitting cause oil is trap in the bearings. The walls can run dry of oil and start to rust.
Just sitting in cold to warm temps over and over will get moister to form on the cylinder walls. Why they sell fogging oil to store engines for long times.
Offline dutch
« Reply #8 on: April 07, 2010 - 04:29:22 PM »
9 out of 10 times the piston is stuck to the rod when it won`t turn over
*** Bart ***
« Reply #9 on: April 07, 2010 - 04:40:32 PM »
Any chance a mouse or two made a home in a cylinder?  There are pics floating around of huge nests found inside engines that have sat around for awhile.
Offline Strawdawg
    • Vortex Buicks
« Reply #10 on: April 07, 2010 - 05:11:57 PM »
If the starter checks out fine, I assume that it was removed to be certain it was not stuck in the ring gear?
« Reply #11 on: April 08, 2010 - 12:59:54 AM »
was the engine filled with water & possibly left outside to freeze , it happens constantly around here , it could split a cylinder wall
