Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
340 HP Exhaust Manifolds on those 318 High Swirl 302 Heads
« previous
next »
Print
Pages: [
1
Author
Topic: 340 HP Exhaust Manifolds on those 318 High Swirl 302 Heads (Read 1401 times)
dodge freak 2
Full Member
on:
April 07, 2010 - 06:54:21 PM »
Anybody try to use them, will the big port 340 HP Exhaust Manifolds seal to the small exhaust ports. I know the smog air holes should be tap and plug, easy enough but unsure if the flange is wide enough to get a tight seal around the ports.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 340 HP Exhaust Manifolds on those 318 High Swirl 302 Heads
Reply #1 on:
April 08, 2010 - 01:13:46 AM »
I am not sure , if you coat the manifold flange with grease to see where it contacts
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
