YES it will work , it is a 4spd but 4th is an OD ratio , there are a # of things to do , First machine the front bearing reatiner down to 4.80" & get a belhousing with a matching size hole , they are available new from Brewers for $300
second most of the time you will need to drill & tap the 3 posts on the tailhousing to mount the shifter & get the different mounting pad & longer shifter rods . The 3/4 shift rod will need to be modified to clear the body & reach the 3/4 lever which is pointed down not up like the rest of the shift rods .
