Author Topic: what kind of k member is this?  (Read 1869 times)
71bronze
« on: October 03, 2004 - 08:28:21 PM »
just trying to verify is this is actually a 440 k member. it's in the drag car i just bought.
doesn't look like the one in my 70 6 popper car.
[attachment deleted by admin]
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: what kind of k member is this?
« Reply #1 on: October 03, 2004 - 09:54:22 PM »
looks like an 8cyl K-member.
Take a pic of the the I.D. plate on the leading edge drivers side. It is tacked onto the k-member like a dog tag for I.D. purposes.
Then I can tell you for sure what it is! ;D
2013 Tige' RZR 343hp
71bronze
« Reply #2 on: October 04, 2004 - 12:03:18 AM »
don't see a tag of any kind, or any numbers pressed into the front edge. is that where it always is?
« Reply #3 on: October 04, 2004 - 01:00:23 AM »
looks like a normal V8 K to me
Offline JS27N0B
« Reply #4 on: October 05, 2004 - 10:10:14 PM »
I need a pic of exactly what the radiator top cross bar is blocking from veiw at the bottom of that
picture. take it from k member height from the front.
Offline purple6popper
    • pics of my projects
« Reply #5 on: October 08, 2004 - 09:57:27 AM »
here are the pics you asked for
I found the meaning of life once, but forgot to write it down.
Offline JS27N0B
« Reply #6 on: October 09, 2004 - 10:40:28 PM »
Guess what!
The I.D. tag is not where it is supposed to be.
Definitely  a V-8 K, not a 6pk one though.
Plum6Pak
« Reply #7 on: October 09, 2004 - 11:42:52 PM »
70-74 V8 K frames are all identical, even the 6Pak ones with the exception of the hemi, there is a number on the front that designates a 6pak K frame but it is identical to the 318 K frame. If you are building a correct numbers matching car, the number will be important, if not, use it in anything but a hemi.  :D
« Reply #8 on: October 11, 2004 - 10:33:27 AM »
schweet!!
now i just need to find a 400.
already have a 440 with 906 heads and a forged crank located. $500
going to build a 451.
« Reply #9 on: October 13, 2004 - 08:19:52 PM »
just to clarify the 6 pack K frame has the skid pad to protect the pan wleded to the bottom of the K frame , other than that it is identical to the other V8 K frames
Offline JS27N0B
« Reply #10 on: October 13, 2004 - 09:48:15 PM »
Exactly why I said not a 6pk one.
