I picked up a battery quick-disconnect ---everstart makes it.....one of those deals where you unscrew the big knob to disconnect power....the label calls it a "swan terminal discoonect"
On the package directions it says to use this on the battery + terminal......then connect the battery + cable to it. Thing is, the clamp on my battery + cable is too big for the post on the disconnect.
So I used it on the "-" instead.
Anyone see an issue with that?
I was always taught to always remove the ground first anyways....so I think its OK.....but why would the package say to use it on the "+ side?
I found a site selling them and they show it on the "-" side too....
They also show a fused bridge to allow the radio to keep power when the green knob is removed......is this safe?]'
I wired in a 2a fuseholder for that purpose. That means that I will still have to pop the clamp off the battery when I am doing service and need power disconnected, but when I pull the knob for security the fuse will blow instead of crank, right?
